Paging MustangEater
gol10dr
02-17-2004, 12:17 PM
I was wondering if you could possibly give me a hand changing out my rear sometime, You'd be an asset since you've done it before. I finally have calipers coming from Billy Graham so they will be here tomorrow. Email me at Sarkj@ocps.net
2002Z28SSConv
02-17-2004, 12:21 PM
Billy Graham :thumb:
MustangEater82
02-17-2004, 11:06 PM
Sure I might not know much about puttig the calipers on but I have pulled the rear and put it back on... actually more then once :think:
I just need to figure out a time, got school/work.
gol10dr
02-18-2004, 07:31 AM
the calipers are pretty much straight forward to put them on, I just need help putting and taking off the rear.
darkoverlift
02-18-2004, 08:24 AM
So you need more of a supervisor who has done it before in-case you run into little quirks because removal should be easy...
'94 Bad A Z28
02-18-2004, 09:39 AM
I was just thinking about this, what are you going to do about reprograming for the gears?! Also, did you change the rear fluid and add the posi additive yet? If not you really need to do that and it is a lot easier to do with the rear out of the car.
darkoverlift
02-18-2004, 09:42 AM
Ya I helped him on that.. He tosed in new Amsoil Synthetic fluid and gm posi additive.
'94 Bad A Z28
02-18-2004, 09:43 AM
:cool:
darkoverlift
02-18-2004, 09:44 AM
Boy did that gear oil stink.. It stunk my garage up, and some of the inside of the hosue. I had to move the rear to the back yard it was so bad...
'94 Bad A Z28
That still leaves the question about reprograming for the gears?!
darkoverlift
02-18-2004, 09:45 AM
He is ordering the Jet Scu 2000. It will correct up to two gear changes so he can go as high as 3.42 if he wants and the shift points and speedo will be correct.
'94 Bad A Z28
02-18-2004, 09:46 AM
Lol.... :D My bad!!!! :D I tried to do it for him. But I waited too long and didn't have time to go get the right tool to get the plug out, lol.
'94 Bad A Z28
02-18-2004, 09:47 AM
:cool:
