zulater91
02-16-2004, 09:30 PM
I have a problem with starting my car. I try to start it and it sounds like a couple cylinders are firing but then does not start. If I keep the motor turning over it sounds like it wants to start but then nothing. I smell a lot of gas too. I have tried to time it repeatedly but I think if I got close, it would run. Any idea's I can try maybe sensors.
DanD 96 SS
02-16-2004, 10:59 PM
Give some more info, like did it run one day and not the next, was it just worked on ( are the plug wires on right), was the motor just rebuilt ( is the distributer in 180 degrees off). If it just stopped running I would bet it is the control module. Could be a cracked or shorted dist. cap, bad coil , coil wire, etc.
Good luck
Dan
zulater91
02-17-2004, 12:23 AM
well it ran before just fine then I pulled the tranny to do some work on it. i put the tranny back in then it did start back up that night but the next morring i tryed to start it and no go. so from there on it hasnt started. like i said it trys to start but nothing. it is a brand new motor but i had it running and it ran good. but now i cant figure it out. any help would be great.
trackbird
02-17-2004, 01:00 AM
Did you pinch the distributor (or any of the) wiring harness between the block and transmission? I managed to do that once when installing a transmission late at night and had to pull it loose and move the wires. Maybe you smashed a wire and after sitting overnight being "crushed" by the bellhousing, it split the jacket and shorted to ground. That may explain your problem, just a guess.
Good luck!
zulater91
02-17-2004, 11:50 AM
I looked at all the wiring it all looks good to me
TheGreatJ
02-17-2004, 01:41 PM
When you had the tranny out did you let the engine rock back? The motor mounts allow enough movement for the distributor to hit the firewall and it will crack the cap every time.
zulater91
02-17-2004, 02:19 PM
i thought that was the problem too so i replaced the cap and still nothing.
angel71rs
02-17-2004, 02:32 PM
I had same problem on my 89 Formula; wouldn't start, strong odor of gas. Pulled a spark plug and it was dripping wet. Turned out to be ECM in my case. Read here:
http://web.camaross.com/forums/showthread.php?s=&threadid=197446&highlight=flooding
zulater91
02-17-2004, 04:08 PM
so you didnt change the prom?
angel71rs
02-17-2004, 04:46 PM
I put the stock chip in the original ECM just to see if it was the Hypertech prom casuing the flooding. When that didn't fix flooding, I changed the ECM. Ran the replacement ECM with the stock chip for a while to make sure problem was fixed. Then I reinstalled the Hypertech. Still running like a champ.:)
zulater91
02-17-2004, 07:14 PM
So could i just go to a junk yard an pull a 91 z28 ecm out and try it. Or are there different ecm for that year.
angel71rs
02-17-2004, 09:26 PM
Doesn't have to be from a 91 Z28, other vehicles ECM's interchange:
http://www.thirdgen.org/newdesign/tech/ecminterchange.shtml
Prom is application specific. I bought a rebuilt ECM from Checkers for 90 bucks.
Are the plugs wet? Did you investigate other possible causes of excess fuel, such as the regulator?
zulater91
02-17-2004, 09:28 PM
how would you know if the regulater is bad. i have a gauge on it and it is holding 40psi when it primes up and then 46pis when starting.
