WTB LT1 water pump drive seal tool and bose speakers.
Old Feb 16, 2004 | 06:29 PM
Z95m6's Avatar
I'm in need of the special LT1 water pump drive seal tool. My seal is leaking on my new motor and i need to replace it. I figure i must need the tool cause my brand new seal is leaking. I also need the 2 rear qtr. speakers for a 95 bose system. I think my door speakers might be on their way out too so if you have a whole set i might be interested in those too.
Old Feb 16, 2004 | 11:03 PM
groundpoundinlt's Avatar
do you need the speakers right at the back seat?? if so i got them and i think i have the door ones too...let me know if interested
thanks
bubba
Old Feb 16, 2004 | 11:07 PM
ddr698's Avatar
Your waterpump drive may be wore to the point where it needs replaced and not matter how the seal is installed it will still leak, just something to check,
Dan
Old Feb 16, 2004 | 11:16 PM
jssws-6's Avatar
I have the speakera from the rear 1/4 panel all 4 and I have the door speakers for sale from a monsoon system! 97 TA all in great condition with the wiring conectors still attached. $55 shipped
Old Feb 17, 2004 | 01:45 AM
Z95m6's Avatar
You guys have PM's on the speakers. Dan do you mean the coupler shaft is worn enough to have a groove and cause a leak or the actual drive inside the block is worn and causing enough movement to make it leak.
Old Feb 17, 2004 | 09:18 AM
jssws-6's Avatar
The speakers are from a 97 TA with about 60,000 when they where removed. I don't know if the bose and monsoon are interchangable. I don't have the ones from the rear seat I have the door speakers and the 4 speakers from the rear hatch area. If your interested $50 shipped, They all work great
Old Feb 17, 2004 | 10:44 AM
Z95m6's Avatar
well thanks for the offer jssws-6 but i want to use all bose stuff to make sure it works. I really only need the rear seat area speakers and i wouldn't mind some new door speakers. My car only has 2 speakers in the doors, 2 in the rear seat area and one sub in the hatch so i don't think your speakers would work for me. Thanks for your time though.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
u2slo5point0
Sep 9, 2002 05:44 PM
