What gear ratio is best with Nitrous & 6spd...
Old Feb 16, 2004 | 02:33 PM
roguedriver's Avatar
Getting ready to order a new 12 bolt and was looking for input about which gear ratio to go with. I currently have 4:10's in my 95 camaro with a 6spd. On the bottle, I go through the traps in the 1/4 just under 6000 rpm in 4th gear with a set of ET streets. Should I stick with 4:10's or drop down to a 3:73? And if I dropped down, how much would I lose? What are you guys running in your 6spd nitrous setups? Last track day, I ran 12.6 at 120mph with a 2.0 60ft. Should run 11's if I can get my 60 ft down. Any input would be appreciated. Thanks.
Ken R. 95Z
Old Feb 18, 2004 | 10:43 PM
sharp396's Avatar
I run 3.89's and I had a 150 shot on my old motor with 26" tires, I was just getting to the top of 4th at the traps.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Jul 4, 2005 05:00 PM
