1984camaroz28
02-13-2004, 08:30 PM
will et streets kill my 10 bolt. im making around 650hp. what can i do to build up my 10 bolt to handle this kinda hp. I dont wana spen 2grand plus on a 12 bolt
10 bolt1984camaroz28 02-13-2004, 08:30 PM will et streets kill my 10 bolt. im making around 650hp. what can i do to build up my 10 bolt to handle this kinda hp. I dont wana spen 2grand plus on a 12 bolt chpmnsws6 02-13-2004, 08:49 PM don't heat em up, don't stall it up, run it at half throttle 1984camaroz28 02-13-2004, 09:01 PM there is a way to build up my 10 bolt Black6SpdTA 02-13-2004, 09:10 PM Originally posted by 1984camaroz28 there is a way to build up my 10 bolt For 650 hp? With ET Streets? I doubt it but here's the help I can give you: -Support Cover (TA, MAC, etc) -Weld the axle tubes to the housing -If you're talking about your thirdgen, upgrade to 28 spline axles -Super Duty posi unit (Zexel HD, Eaton, etc) -Run a gear lower than 4.10's, they seem to be more stressful on 10-bolts AFAIK, these are all the performance mods to a 10-bolt. Good luck. 1984camaroz28 02-14-2004, 01:28 AM i saw in one mag a impala with 800 hp supercharged on a 10 bolt but it had a 800pound eaton posi unit where do i get one Black6SpdTA 02-14-2004, 09:11 AM Originally posted by 1984camaroz28 i saw in one mag a impala with 800 hp supercharged on a 10 bolt but it had a 800pound eaton posi unit where do i get one Summit sells Eaton stuff. Don't know about that heavy duty stuff though. www.SummitRacing.com chpmnsws6 02-14-2004, 11:47 PM it is also an 8.5 inch 10 bolt. you have a 7.5 inch 10 bolt :( the 8.5's can handle alot more than these can | ||
