LWillmann
02-12-2004, 05:31 PM
Is it possible to remove the clutch pedal assembly from the vehicle without removing the steering column?
clutch pedal assembly removalLWillmann 02-12-2004, 05:31 PM Is it possible to remove the clutch pedal assembly from the vehicle without removing the steering column? LWillmann 02-13-2004, 09:56 AM ttt Brent94Z 02-13-2004, 11:36 AM This would probably be better suited for the Drivetrain forum. Since you aren't getting any answers here, I'll move this over to that forum for ya. 95wannabe 02-13-2004, 06:45 PM probably not possible...not sure why you're removing it, but if you've gone this far... 1 bolt at the u-joint will disconnect column from shaft under the hood, 3 bolts will remove collar holding column to firewall, an just 2 more will drop column down from the dash, then you'll have 3 or 4 wire connectors to unplug 961le 02-13-2004, 08:05 PM yes. i did it ,you will leave with some battle wounds though. not too bad. | ||
