3800 supercharger
Old Feb 10, 2004 | 10:48 PM
00SilverStar's Avatar
3800 supercharger
I have been thinking. The grandprix gtp as the m90 on it. they use the same 3.8 v6 that is in the camaro. How much work is needed to transplant the setup from a gtp to a v6 camaro. the only spot i saw with a prob is the tb. it would be right next to, if not up against the fire wall. has anyone done this,
thanks
Frank
Old Feb 11, 2004 | 09:07 AM
Pro Stock John's Avatar
www.firebirdv6.com has talked about this many times.
Old Feb 11, 2004 | 09:12 AM
IDOXLR8's Avatar
Have you looked into a Grand National motor swap? (3.8 V6 Turbo)
Old Feb 11, 2004 | 10:27 PM
havent looked at the gn, wonder what it would take to get that runnin in the car
Old Feb 12, 2004 | 02:56 AM
aram's Avatar
Throttle body outlet would be on the wrong side.. only way I could see to do it is by using an aussie blower of a holden car or using an adapter that has the curve to allow the tb to be mounted in the right spot.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
