What aftermarket SS Hoods look the closest to the real thing? ASCD?
Speeds8erM-1
08-12-2002, 06:24 PM
What aftermarket SS Hoods look the closest to the real thing? I call tell a Suncoast, US Body and A&A from the real thing. Does the ASCD look like the real thing?
1980 Camaro Z28 Sikkens 3 Stage Blue and Purple
1994 Camaro Z28 Teal M6
Ported Heads, LT4 Hot Cam and Springs, 1.6 RR's, Mac Headers and Offroad Y Pipe, Flowmaster Catback, Resonators, Flowtech Cutout, NX 150 Horsepower Shot of Nitrous, NX Bottle Heater, NX Remote Bottle Opener, NOS Purge, KB DD SFCs, BMR STB, Hypertech 160 Thermostat, Redline Water Wetter and Synthetic Diff. Fluid, McLeod Dual Performance Clutch, K&N FIPK, LT4 KM, 1LE Bellow, Holley 58mm Throttle Body, TB Coolant Bypass, Metco Valve Cover Breather, LPW Rearend Support Cover, Strange 3.73s, Eaton Posi, TA Stud Kit, Lakewood LCAs and Adjustable Panhard Rod, LS1 Driveshaft, March Underdrive Pullies, MSD 6AL, MSD Window Switch, MSD Blaster Coil, NGK TR6's, Mobil 1 Synthetic, Pro 5.0 Shifter, Intrax Lowering Springs, BFGoodRich Comp TAs 255/50/16, Nitto Drag Radials 245/50/16, AVS Blackouts on the back.
339 RWHP Corrected with two broke rings
465 RWHP Corrected on the nitrous with the clutch slipping bad and two broke rings
www.geocities.com/speeds8erm1
zlightning
08-12-2002, 06:53 PM
I am guessing SLP considering they make the SS hood.
1995 3.4L v6 Camaro FIPK Spintech Cat-back.
Curt (pres AAMC & ZAA)
08-12-2002, 08:16 PM
Well, my ASCD Ram Air hood is an exact duplicate of the original down to the same waves in the surface that I've seen on every factory Ram Air hood. In fact, I'm using original GM Ram Air grills in my hood and they fit perfectly.
The only way I can tell them apart is by looking at the underside of the hood. The original is smooth in the airbox cutout area, but you can see some of the fiberglass texture on the ASCD.
Speeds8erM-1
08-13-2002, 04:25 AM
Thanks! How does the hood fit? How much does it weigh?
08-13-2002, 05:33 AM
The fit was very good. I installed it with the help of a friend. I had to drill two holes for the hinge locator pins and do a little filing in the secondary latch hole and that was it other than making adjustments to the latch. When I took it to get painted, the body shop seemed impressed with the quality, and after four years, I have no compaints. It's held up very well, and even withstood a cigarette that someone decided to let burn out on my hood. It burned the paint, but the hood was fine.
I don't know how much it weighs though. I don't recall it being much lighter than the stock hood. ASCD should be able to tell you exactly how much the hood you're looking at weighs.
Viper
08-13-2002, 08:40 AM
I met the guys who own ASCD here local to me at a big Car Swap Meet they come to every year. They told me that there SS Hoods are exact duplicates, as they purchase a real SS Hood to make the mold with. I bought my 98 SS Hood from them and the fit and finsh is great and uses the stock SS grille, just got it back yesterday from the paint shop http://web.camaross.com/bb/smile.gif
Viper
Speeds8erM-1
08-13-2002, 04:12 PM
Thanks guys! I am going to find out the weight on the hood because I do want a lighter hood.
Rickm
08-13-2002, 04:17 PM
I changed My '98Z28 stock hood for a GM SS hood and They weighed the same.
Rick
'65 Malibu SS - 280rwhp/330ftlbs
'98 Camaro Z28 - 318rwhp/334ftlbs - Sold 7-18-02
'02 TransAm - Brand new No dyno Yet
D-flo lid, GMS, Hotchkis STB, Hurst B+
Bat-CaveOnline (http://www.bat-caveonline.com/CarPicsindex.htm)
Speeds8erM-1
08-13-2002, 04:48 PM
I called ASCD, they said the hood weighs 45 pounds. How much does the stock hood weigh? I dont feel like taking mine off and weighing it. http://web.camaross.com/bb/smile.gif
Speeds8erM-1
08-13-2002, 05:32 PM
I found out the stock hood weighs 44 pounds. I dont want to get another hood that isnt lighter. I called VFN, their 2 inch cowl induction hood is 26 pounds for the bolton. I just have to decide if I like that hood or not. http://web.camaross.com/bb/smile.gif
