94Camarov6SS 02-06-2004, 03:02 PM I am wanting to know if anyone can tell or show me how to get rid of the ever annoying governor switch. My governor hits at 115 and I know my car can do well over 140..... I have a 94 3.4L and need this removed. Is there any way???????? Thnx for input Soccaballa2k4@aol.com
jonaddis84 02-06-2004, 03:11 PM Not very "Advanced"....but its in the computer, and dont be so sure your 3.4 will do that, at least not very quickly. Your car probably didnt come with Zrated tires, no reason to, and if its an automatic or a convertible you will have a guvnor.
Your PCM will need to be reprogrammed in other words.
94Camarov6SS 02-06-2004, 03:16 PM I have a Governor, I've hit it before, and it's a regular ole V6. Is there anywhere u know of where I can take it or what kind of business will do it or anything I can buy to do it myself. THnx
rmackintosh 02-06-2004, 03:22 PM pcm4less
94Camarov6SS 02-06-2004, 03:27 PM Explain what this is and what it does? PCM4LESS????
Injuneer 02-06-2004, 04:35 PM This question could probably be answered in about 2 minutes on "V6 Tech"...... moving it there.
oil pan 4 02-07-2004, 07:45 AM You can pull the VSS that might work.
NoSlowCamaro 02-07-2004, 11:43 AM You can buy programmers to remove/raise the govenor, rev limiter, etc...But dont get your hopes up too much...i really doubt your car will do "well over 140"...unless you got some serious mods..like an LS1 under the hood:D ;) jk
94Camarov6SS 02-07-2004, 02:38 PM Your crazy, the LS1 can do about 200, I did 140 in a damn 4 cylinder Camry. But newayz where can I get this Programmer and how do I pull the VSS and where is it?
99blackSS 02-07-2004, 04:37 PM When I topped out the V6 camaro I had (98 3.8l) I got up to 118mph (probably a 115mph limiter) and the rpms were pretty high, you might be able to get close to 140.
I don't know what the LS1 is cappable of. The majority of them have a 160mph speed limiter, which most people don't have a need to remove.
94Camarov6SS 02-07-2004, 05:15 PM Well you hit governor in 4th at only 4 1/2 RPM's and you still have a 5th. If it's an automatic the top speed is gonna be slightly different. But my governor is wierd, sometimes it kicks in 115, or 110, one time it let me get to 120....I just wanna get rid of it.
NoSlowCamaro 02-07-2004, 05:31 PM Originally posted by 94Camarov6SS
Well if the V6 5 speed is like the Z28 6 speed...your top gear is useless..my friend's 6 speed Z28 uses 5th gear to max out..when he shifts into 6th @ around 150 or so..he claims that he either doesent accelerate, or most of the time he actually starts slowing down. So if your car is like that..than it probably wont pull 5th gear. Also..i would like to see what LS1 is out there right now doin 200 mph, w/out serious, serious motor work...vettes cant even do 200..there lighter, and more aerodynamic.
MustangEater82 02-07-2004, 05:55 PM eventually the drag on your car will keep you form accelerating...
no way are you going... well over 140 mph in a 3.4L maybe 130-140 but not well over 140
jsut unhook the VSS, not aure if it works on autos...
99blackSS 02-07-2004, 06:03 PM Originally posted by NoSlowCamaro
Well if the V6 5 speed is like the Z28 6 speed...your top gear is useless..my friend's 6 speed Z28 uses 5th gear to max out..when he shifts into 6th @ around 150 or so..he claims that he either doesent accelerate, or most of the time he actually starts slowing down. So if your car is like that..than it probably wont pull 5th gear. Also..i would like to see what LS1 is out there right now doin 200 mph, w/out serious, serious motor work...vettes cant even do 200..there lighter, and more aerodynamic. I was thinking the same thing about the 6 speed cars topping out in 5th. But fifth and sixth gear are both over drives in the 6 speeds, so the fifth gear in the V6 Camaros might have some pull in it, assuming fifth is the only over drive gear. I still think it will get some where in the 130s.
oil pan 4 02-07-2004, 08:24 PM On the L460E There are 2 speed pick ups.
1 is a "govener switch"
2 is the VSS
The governer switch is on the left side infront of the tail shaft houseing near the top of the transmission.
The VSS is on the transmission tail shaft housing its self near the bottem leave that one.
Find out if the switch is normaly open or normaly closed, if you cut the wire and your car doesn't work it's normaly closed and you will need to ground it to the frame some where (or short it to the other wire coming off the govener if there is one). If it works fine after you cut it tape it off so it dosen't flap around and ground out.
If you have a T-5 there is the VSS (near the top or left side past the back half of the trans) and that is all I rember being on the trans and on a 92 (highest yr. my book goes to) the VSS is conected to the ECU.
So you might have to kill the govener switch and cut the VSS where it goes into the ECU.
Your speed "O" is eletronic so pulling the VSS might mean a dead speed o unless you cut it where it goes into the ECU.
On my 85 I can cut it because my speed o is mechanical and the VSS is only an ECU pick up.
Need4Camaro 02-07-2004, 11:05 PM The fastest I've ever seen a V6 go was about 138 MPH with the limiter cut and it was a 3.8 giving some good RPMS... All cars are different so undoubtfully even for 3.4's some are slower and some are faster... but well over 140 MPH???... "Are you SURE thats no V8 under your hood?"... even with simple mods and good tires it's still close to impossible of pulling that off with a 3.4.
I believe the limiter is programmed into the CPU so you're going to have to get an aftermarket reprogrammer to take it out, hope this helps.
94Camarov6SS 02-08-2004, 01:28 AM Alright, I have the T-5 and the 5th gear does have pull, it accelerates good and sometimes if I put it into 5th before I govern I can get up faster. I can do 140+ without the governor trust me. If you could shoot me an email Oil Pan and explain it a little further about the VSS removal then I would try that out even w/o speedometer. But I'm talkin about maxing the car out and I've seen a stock LT1/LS1 go about 210 w/o governor. My 3.4 isn't stock, I have a modified exhaust, intake, and I'm about to get some other stuff like NOS. Well plus I'm gonna need to get rid of it if I'm planning on droppin my LT1 LOL. Unless you can put the LS1 VSS in my car? Thnx Soccaballa2k4@aol.com
99blackSS 02-08-2004, 01:48 AM Originally posted by 94Camarov6SS
I've seen a stock LT1/LS1 go about 210 w/o governor. I was going to let the 140mph in a 4 banger fly... but now I have no other choice... :bs:
NoSlowCamaro 02-08-2004, 10:28 AM Man..this is like...those ricer nightmare's i have..where some guy is at the gas station with his honda accord telling ppl "it can do 180 mph because ive seen a 911 carrera twin turbo doin 180 and I can almost hang with one for a couple of seconds"........except this is worse...Because this guy drives a Camaro, not a ricer. But this isnt any old camaro...its a V6 SS. :D :rolleyes: JK man..good luck gettin your govenor removed..and have fun with your car.
94Camarov6SS 02-08-2004, 01:55 PM Man I'm tellin you what I know, and I hate the sorry ass imports.... they can't take ****. I have my name V6SS because I bought a V6 for the chassis to drop a LT1 and do the SS Conversion with all the 02 body panels.
fourthgen9534 02-08-2004, 06:56 PM On a t5, the vss is on the driverside all the way on the back of the tranny. I just spliced a toggle switch into one of the wires going to it. When you turn the switch off, it kills the signal going to the pcm........You can go faster than the speed limiter with it, but the speedo doesn't work. I've had my 3.4 at 130mph next to another car.
ImportKILLER 02-08-2004, 10:22 PM This thread makes me :lol: and :rolleyes: at the same time.
oil pan 4 02-11-2004, 04:23 AM When I had a POS 2.8L in my 85 I could do 105-110 no problem it still had some pull even at that speed.
That car felt like it was built to ride 85-90mph smooth and perfect(compaired to all other speeds) taching about 2200rpm.
D@mn those S rated tires! Even worse there still on there with the new 3.4 and crane cam and they have been sitting over a year.
I didn't want to push it, at all at those speeds.
oil pan 4 02-11-2004, 04:27 AM Look at that link in importKILLER's sig.
It will make you sick.
stars1010 02-11-2004, 08:33 PM This is the most laughable, ridicules thread I’ve read in quite a while.:rolleyes:
