question about purge kit
blazzinbird
02-05-2004, 10:45 PM
is there a way to make it spray 2 stream instead of 1?
if so how hard is it to do
RacinLT1
02-05-2004, 11:43 PM
it's easy,just have to run a compression T fitting and 2 lines.
basically remove the fitting from the solenoid,replace it with a 2,and then run 2 lines.
blazzinbird
02-08-2004, 02:02 AM
is this purge kit ok
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33740&item=2458378687
and where can i get the t fitting, and what size should it be, and what size tubing do i need
RacinLT1
02-08-2004, 12:36 PM
yeah thats not bad,it'll work.
also go here for a simple dual spray setup....same company sells it...http://www.dynotune.org/store/Scripts/prodView.asp?idproduct=34
DrewHMS97SS
02-08-2004, 03:15 PM
i dont think i would buy one using plastic tube.
