kev311
07-13-2002, 08:17 PM
MY DOOR IS MAKING CONTACT WITH MY FENDER WHEN I OPEN THE DOOR ON MY 97 CAMARO WHAT CAN I DO TO FIX THIS
PLEASE HELP MEkev311 07-13-2002, 08:17 PM MY DOOR IS MAKING CONTACT WITH MY FENDER WHEN I OPEN THE DOOR ON MY 97 CAMARO WHAT CAN I DO TO FIX THIS Zomie 07-13-2002, 10:02 PM Well, have you checked the bolts holding up the door then just may need tightning...and check the lock nut to make sure its in goos shape... Please give more details if that is not it, ------------------ 95 Camaro 3.4L, -Flowmaster muffler 80 series with quad tips, -K&N Air Filter, -White Racing Stripes -LeBra front end cover, -Carbon Fiber headlight covers, -Interior purple neons * 4 8" bulbs * 6' of neon wire * 6" neon that flashs to the bass. -Chrome shifter and pedals -Ice cold Purple! -2000 Trans Am rims with 245/45 R16 tires. http://members.glis.net/zomie Aneurysm 07-14-2002, 01:25 AM The doors are adjustable. If you loosen the bolts, you should be able to slide the door forward and backward a little, and then retighten them. ------------------ 2001 Camaro SS (http://camaroz28.cardomain.com/id/aneurysm) Light Pewter Metallic M6, T-Tops, Ebony Leather All Options kev311 07-14-2002, 04:23 PM thanx for the help guys. it is no longer doing that. it really wierd. do u think that the heat may have expanded the door and fender or is that not possible. ill still check the bolts and adjust a little back so it wont happen again. thanx. trefidy 07-14-2002, 09:40 PM Ya know, I had the very same thing happen years ago to my 93, my fender was pushed in just a little and my door would pop when opening. I took a closer look and pulled out the fender and to this day no more prob. ????? kev311 07-15-2002, 01:49 AM trefidy what do u mean "pulled out the fender" what exactly did u do kev311 07-19-2002, 08:57 PM which bolts do i loosen to adjust the door back kev311 08-06-2002, 12:32 AM still having trouble any more options???? | ||
