c0rey 02-03-2004, 11:09 PM Post you speedo gauge pics and ect. I was thinking I want to swap all autometer gauges in place of my factory gauges not sure. I just think it would be sweet looking.
Post up some pics. :D
White face pics would be sweet as well.
LimitedEd1LE 02-03-2004, 11:25 PM Pics are in my sig. Check them out.
blackz151 02-04-2004, 12:09 AM i wanted to do somthing like that 2 but i donno if will put ne SES lights if it doesnt see the gauges there
Injuneer 02-04-2004, 01:16 AM Originally posted by blackz151
The PCM does not interface with the fuel level, oil pressure, coolant temp or battery voltage gauges, so no problem substituting non-factory parts.
The VSS signal passes through the PCM, where it is modified to reflect rear end ratio and tire diameter. You could run the VSS signal in parallel to the PCM to keep it happy, and also to a Dakota Digital interface box, to produce whatever signal an aftermarket speedometer/odometer is looking for. The tach comes off the PCM, but an aftermarket tach could be driven off the coil.
95Zdroptop 02-04-2004, 02:06 AM http://www.cardomain.com/id/tlh123
rlax31 02-04-2004, 07:13 AM Day (http://www.radford.edu/~rvandenhe/Pictures/97_Z28/images/gauge2.jpg)
Night (http://www.radford.edu/~rvandenhe/Pictures/97_Z28/images/gauges%20night.jpg)
MEATHEAD 02-09-2004, 09:58 PM www.teamprickracing.com/95z/day3
I just built mine this weekend....
ErockZ28 02-09-2004, 10:04 PM Originally posted by rlax31
where did u get that? thats the one i want :)
rlax31 02-10-2004, 08:42 AM The overlay is off ebay, they're reverse indiglo gauges.
Then I took a Trans Am bezel and put it over the overlays and cut off the corners so that the only thing that is white is dials.
Here (http://www.radford.edu/~rvandenhe/Pictures/97_Z28/images/Gauge%20Progress.jpg) is a picture showing stock, then the overlay, then the finished product
The overlay cost 20 bucks, and the bezel cost about 40 i think from Macewen (http://store.yahoo.com/macewenmotorsports/index.html)
I love the gauges, and always get compliments, feel free to aks any other questions
94_Camaro_LT-1 02-10-2004, 03:36 PM Originally posted by MEATHEAD
:bow: wow :bow: Very very sharp looking!!
MEATHEAD 02-10-2004, 06:56 PM Thanks...
Shannon
Black_Z28 02-10-2004, 09:48 PM Here's the night (http://www.mnfbody.com/memberpages/black_z28/darklights2.JPG) and day (http://www.mnfbody.com/memberpages/black_z28/silvergauges2.JPG) difference.
niteninja 02-11-2004, 04:42 PM Originally posted by 95Zdroptop
How did you get the HVAC and headlight/foglight switches to have so much light?? You can hardly see mine.
BTW, Looks Sharp!
JasonD 02-11-2004, 06:30 PM Originally posted by MEATHEAD
I have always wanted to do that. Can it be done using the factory PCM or is it something that you need to make work a more old-fashioned way?
Black_Z28 02-11-2004, 08:28 PM Originally posted by JasonD
Most gauges made no-a-days are digital. So, all you really need to do is find the correct signal wire, power, and ground wire, and you're set.
MEATHEAD 02-11-2004, 08:48 PM I'm using a F.A.S.T for engine management so the stock computer is gone. It's nothing more than the gauge, power wire, and it's sender. The part that sucks is the 5 hours it took to align and fit all the gauges. I just used plastic from the console to build the gauge clusters.
Shannon
Here is a few more pics of the project:
www.teamprickracing.com/f3sc
jorgez28 02-12-2004, 02:43 PM Where can I get indiglo gauges for a 1994 z28?
94_Camaro_LT-1 02-12-2004, 02:46 PM Ebay :cool:
