Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Great heads for sale cheap!
Old Feb 2, 2004 | 05:21 PM
Timberwolf's Avatar
These LS1 heads have 2.02"/1.575" Stainless steel REV valves
Brand New Comp Cams 918 Blue stripe updated spring's with matching retainers
New Felpro LS1 Valve guide Seals
Bronze/magnezium Valve guides
Full CNC Stage 2 Port program by CNC Inc in Penella's Park, FL. including CNC chamber
Full Hand blending, porting and Re-shaping of intake and exhaust runners
Competition valve job radiused to spec
milled .030" for 11.3:1 compression.
These have not even been bolted on since port work!!
Flow numbers:
.200: 152/117
.300: 205/163
.400: 256/201
.500: 289/219
.550: 302/224
.600: 311/226
Comp Cams HD pushrods. .080 wall, .050 shorter than stock (to compensate for head milling).
Head change gasket set
I'll take $1500 for the whole works, This is well over $2500 value! Compare the numbers to other heads out there and you will see how good the port work is, especially in the mid lift area!
http://www.sixtyninecamaro.com/images/ls1heads/
May take a car trailer in on trade for these...
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
