Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Injector info needed
Old Feb 2, 2004 | 08:46 AM
MichiganSkip's Avatar
Anyone know where to get O-rings for SVO injectors?
TIA
Skip
Old Feb 2, 2004 | 01:28 PM
97 6SPEED Z's Avatar
Yep, your local True Value Hardware store.
Long story made short: Bought used 30#/hr. SVO injectors off of a board member here that had 4,000+ miles on them and I wanted to replace the "O" rings before installing them to minimze the chance of having ANY fuel leaks. I went to my local Chevy dealer and they only sell a "seal kit" for the injectors and they wanted $18 + Tax for the "kit". I then took one of the old "O" rings to True Value and the hardware guy matched it up, and I bought 18 of them, (i.e. with 2 "spares"), for $.19/each, that's $3.42 + Tax.
Now I'm NOT positive but I think I remember that the size "O" ring you need is the No. 31(?) I found out that "O" rings come in numbered "standard sizes", and I'm pretty sure(?) the #31 size is what you want.
You're welome!
Old Feb 2, 2004 | 03:36 PM
Grover's Avatar
Are these o-rings comparable material wise, or will they disintegrate due to the heat of the engine/gasoline?
Old Feb 2, 2004 | 05:15 PM
Hot Rod Hawk's Avatar
To each there own on hardware store stuff. Grover is ask'n all the correct questions about what tim allen is talking
I'd rather use o-rings spec'd for injector/ fuel use.
All automotive injectors are the same size as far as o-ring size go's.
The chain parts stores have them in sets. MSD also has them on there website.
Old Feb 2, 2004 | 10:46 PM
Thanks guys!
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
Wilson
Jul 21, 2002 05:08 PM
