V6 R&D + mods from japan
oil pan 4
01-30-2004, 05:18 AM
http://www.gmvsford.com/forums/showthread.php3?t=2438
So far I have
The Saab inter coolers are up frount ( stock).
The 2 small things behind the intercoolers are stock RX7 by pass valves (If you are a ricer that means there "JDM" blow off valves, big whoop).
The throttle body is stock LS1 a with a heavly altered V6 IAC bolted on it.
The upper and lower plenum is from a 2.8 and the intake manifold is from a '94 3.4L camaro.
The heads are from the last 2.8 I killed.
The turbos are stock 2001 Audi VW K03's
Not shown I have most of a set of after market nissan 180Z turbo and intercooler piping, a few RX7 elbows and pipes and a down pipe for one of the turbos (need one more).
oil pan 4
01-30-2004, 05:20 AM
http://www.f-bodytech.com/forum/showthread.php?s=&threadid=2702
http://www.f-bodytech.com/forum/showthread.php?s=&threadid=2719
:metal:
MustangEater82
01-30-2004, 12:02 PM
Awesome! :metal:
Can't wait to see that thing run!
ImportKILLER
01-30-2004, 07:42 PM
Heyyyyyyyyyy :( ....first thing I thought was "Hmmm...JDM".
kevin 2.8
02-01-2004, 02:57 AM
summer is coming
atl2001
02-01-2004, 03:45 AM
why not run gen 2 or 3 heads?:confused:
kevin 2.8
02-01-2004, 02:19 PM
i think for less compression -which is better for turbo
oil pan 4
02-01-2004, 05:41 PM
I don't run gen 2 or 3 heads because:
The fuel rail, I don't know what it looks like, I need a vac/boost reactive fuel pressuer reg that's also ajustable I don't know what kind the 3x00 engines have, do you?
I got the heads for free.
I can't machine valve spring guides or seats because I think the gen 2, 3 heads have weird looking angled springs and valves.
I also have a fuel rail tap that I need on the camaro fuel rail.
I want to beable to boost a stock camaro short block for now.
How would you put a LS1 tb on a 3x00 intake?
I don't know if I can get forged deep enough dish pistons for 48cc combustion chambers on boost.
I have drilled and taped coolant holes in the intake manifold for the turbos, I dont know if I can do that with the 3x00 intake manifold.
That's all I can think of now.
