FS:94 Z28 OEM FRONT END and misc parts
Old Jan 29, 2004 | 03:16 AM
JWINN's Avatar
All parts are off my personal 1994 Camaro Z28 Black 38,000 miles. Body parts are in great shape! No dents or rust. Car never seen a winter.
I have the complete frt end of the car forsale from the firewall forward plus the frt clip has custom bent J bars that could be welded to a persons current cage easy, these are made from chromoly tube.
$750.00 takes it all
OR will seperate:
1.Stock OEM hood $150.00
2.Frt OEM Fenders both right and left. These will be sold as a pair. $300.00 for both
3.Radiator support.
4.Frt OEM nose or bumper cover(NO DAMAGE) Includes OEM fog lights. $200.00
5.Stock steel drive saft.$10.00
6.OEM gas tank with sending unite and pump. $100.00
7.OEM center counsole with OEM shifter for 4L60E (Auto) $125.00 Great Shape, Not broken
8.Complete steering colum with OEM wheel has good air bag. Or just wheel. Wheel and air bag $100.00 Great Shape.
9. Passenger side air bag. $50.00
10. Rear Bose sub.$25.00
11.Two Bose door speakers. $25.00 ea.
12.OEM rear hatch with glass. Perfect condition $200.00
13.Frt windshield $200.00 No cracks or chips.
14.Rear Interior plastic side panels. $25.00 per side.
15. Opti Spark for 94 Z28 that takes the splined dowel. New only used for little over 1 year. $50.00
16.Stock OEM throttle body with TPS,IAC sensor but will not include IAC housing. $25.00
17.OEM Spare Tire $10.00
18.OEM FUEL LINES. $25.00
19.OEM Frt coil springs $20.00
And what ever else you can think off that is found in the frt end of the car or under the dash. Wiper motor and arm assembly,ABS,Cruise and so on.
20.NEW NEVER USED! Weld Aluma Star 2.0 rear rims 15x12 with bolt circle 5x4.750(Chevy) with 3" back space along with mounted and balanced(Brand New) MT ET Street tires. Also MT tubes. Rims have not been drilled. Tires are 31x16.5x15.
$750.00
If looking for a high end motor that is complete from the custom direct port nitrous system to the Canton oil pan then look no further because I have a complete NEVER FIRED 9 second LT1 for sale:
Agostino Racing Engines built nitrous setup, 396ci LT1 with everything new except the reuse of the block that has been gone thru by ARE. AFR heads, LT4 custom intake and ported along with ASSM NEW MONO BLADE TB with Jeff Prock direct port Pro Race Fogger that has been flowed and corrected also to include three tuneups from Prock, nitrous setup is adjustable to add 50 to 600hp,o-ringed,custom Diamond nitrous piston and so on. Motor will be sold with Factory OBD1 ECU including harness plus many other parts associated to the motor. If your looking for a documented motor from the builder that is brand new and never fired then consider this engine that is available now without the wait. Have reciepts to show $17,000.00 invested to build.
$10,000.00 OBO
If interested call me or shoot me a e-mail for further info on the parts listed: jim.winn@irwinmortgage.com or 616-813-9296 I'm also located in Grand Rapids, MI if considering picking up parts.
Thanks,
Jim
Old Jan 29, 2004 | 09:09 AM
grumpy Z's Avatar
Sent you a PM.
Old Feb 1, 2004 | 11:24 PM
JWINN's Avatar
TTT
Old Feb 2, 2004 | 03:21 PM
The Gremlin's Avatar
Is this the stock non vented optispark unit for 94? Thanks.
Old Feb 2, 2004 | 03:25 PM
JWINN's Avatar
That is correct.
Old Feb 2, 2004 | 03:43 PM
U have any guess as to how many miles are on it? I don't wanna go through the install work for it to last like 2 weeks.
Old Feb 2, 2004 | 06:39 PM
Grover's Avatar
Are the upper shock/spring mounts for sale?
Old Feb 2, 2004 | 07:08 PM
FacelessZ's Avatar
Are you negotiable on the front bumper cover? Ive found many going from $50-90 and I dont need the fog lights...
Old Feb 3, 2004 | 03:12 AM
JWINN's Avatar
I'm not quite understanding what your looking for? Are you looking for the upper A-arm that bolts into the strut tower of the frt end?
Old Feb 3, 2004 | 03:18 AM
JWINN's Avatar
To help someone out I would go $150.00 but the fog lights will also go with the cover. Below that have to pass.
Old Feb 3, 2004 | 09:30 AM
Mirrorsaw's Avatar
I'll take dibs on the bumper cover at $150 if you're willing to ship it (Obviously I'll pay shipping). Sent you a PM and an E-mail.
Old Feb 3, 2004 | 09:45 AM
JWINN's Avatar
I'll let it go for $150.00 with the fog light but that's with you covering shiping.
Remember this item will more than likely have to be shiped truck freight if ya can't pickup from me becuase of the size.
Old Feb 3, 2004 | 09:47 AM
Mirrorsaw's Avatar
Sounds like a deal. I sent you an e-mail. Get me a shipping price..e-mail me back. Thanks.
Old Feb 3, 2004 | 10:21 AM
Grover's Avatar
I'm looking for the upper rubber mount that holds the spring onto the shock that gets bolted through the shock tower.
In this picture I am looking for part numbers 53 & 54 specifically but also 51 & 52 if you have them.
Thanks to Shoebox for the drawing.
Old Feb 3, 2004 | 11:36 AM
JWINN's Avatar
Now I understand what parts. Sorry but I do not have those items anymore. Already sold the frt suspension.
Sorry!
