My Motor + N20 question
Jason Dove
01-28-2004, 12:33 AM
My motor was built for boost. 383, 9.5:1 compression, MTI ported LT4 Heads, SRP pistons, Eagle H beams and a steel crank (I haven't figured out which one yet, I bought the motor fired but unused). 2 bolt mains (unfortunately)... I run a CC305 (emissions) and that's about all I think you guys would care about.
Anyhow, I had a deal on a blower and it looks like the guy is backing out of it now, so I'm thinking I might switch to Nitrous.
I have questions about if it's reasonable to switch, how much of a shot could I run etc on this motor.
I will run a wet kit, probably NX.
sideways_Into_3rd
01-28-2004, 04:41 AM
craig ran a 250 shot on a similarly built motor ...
then he sprayed a 250 shot on top of 9# after he installed his Strim .. motor held up fine :) tires didnt :D
red
01-28-2004, 09:46 AM
Sounds like you have plenty of short block to handle the power. If I was you I would continue to look for a charger. Your compression is way too low to run N/A or with N2O. You will be leaving a lot of HP on the bench if you don't back up the low compression with a charger.
Jason Dove
01-28-2004, 04:27 PM
Well my car is daily driven NA right now with the 9.5:1, still goes better than my 10.5:1 350 with the same cam did. :) hehe
Anyhow, everyone agree with Red that the low compression makes N2O kind of pointless?
sideways_Into_3rd
01-28-2004, 05:33 PM
it isnt pointless ... u can still spray a lot of nitrous and make a lot of power .. but ud just make more power if u had a higher c/r motor
u'll be better off with a blower .. but a blower with a intercooler will cost an arm and a leg more than a nitrous setup ...
u should stick the n2o on it for now .. buy the blower and then have dual adders for when u line me up ;)
RacinLT1
01-31-2004, 12:13 PM
the 1 advantage you have will be slightly less tress on head gaskets due to lower cylinder pressures. go for the bottle,tune it right,and spray big,have fun.
we spray a 406 that has 9.5:1 with a 150 and it drops from 11.4's to 10.3's.
rskrause
02-01-2004, 09:04 AM
You might want to check out this thread http://web.camaross.com/forums/showthread.php?s=&threadid=219601
Rich Krause
