How to tell if it is a 350??
I was told when i got the car that it had a 350 in it with a rochester quadrajet that needed to be rebuilt and it had a leaky rad! no big deal....something to work on!
But wehn i went to take it thru aircare it is registered with a 305!
Now i asked the previous owner and he was told there was a 350 in it...
So my question is how the hell do you tell if it is a 305 or if someone swithced it out for a 350 somewhere along the line.
I figured i would be able to tell by the power but the czrb is screwed and the timing is off so i can't tell wheather it is just that or if it is a dinky engine...
and if so how much total would it cost to do a full conversion with an early model 350??
thanks
thanks
don't worry about it, people do 350 swaps all the time, when i first ran the car for aircare it came out as a 289ci
lol for got to get the VIN changed...
get the casting # on the block and check out nastyz28.com and decode it, or just ask there. gimme the # or cory the # and we both could tell ya.
good luck, sure hope it isn't a 305... lots of coupes came that way though
EDIT: 350sbc are easy to swap and don't cost much more then the parts you need.
lol for got to get the VIN changed...get the casting # on the block and check out nastyz28.com and decode it, or just ask there. gimme the # or cory the # and we both could tell ya.
Take a rag/scaper and clean the small 'pad' just forward of the passenger side cylinder head. With a good light you can read the code there. It will have a 3-letter code that will verify the exact year and CI and HP of the engine. Post it here and I'll tell you what you've got.
Henson071
Aug 4, 2015 09:32 AM
