LT1 vette fuel rail covers
BigBadBlack93Z
07-13-2002, 03:44 PM
I did a search but turned up nothing. I need to know what else I need to install the covers on a 93 Z. I don't think I have to cut them for the fuel lines. Is there any additional hardware I need to get?
1993 Z28 Black A4
Speed Density RULES!
Visual Mods: C5 wheels 17xBig w/ 245/40-17 on the front, 18xHuge w/ 275/40-18 on the rear, No badges, 1" drop
Performance Mods: 1LE Bellows, K&N FIPK CAI, Granatelli STB, MAC Control Arms/Panhard bar, ES Torque Arm Bushing/Trans Mount, TB Bypass, 4" Mufflex, Timing Tricker, Jet Air Foil, Hypertech Stage 2 Chip, ASP Crank/Alt Pulleys, Adj Fuel Regulator, 24# Injectors, 3.73 gears, Yank 2800, Hooker shorties, NOS 2 stage 50 dry and 75 wet
pu12en12g
07-13-2002, 04:25 PM
Did u get the long mounting hardware ? These actually screw in near the valve covers, and the Fuel Rail covers mount on them. U need 4. I can find the part # if u want.
I have the vette fuel rail covers on my 95, and it did take alot of modification to get them to fit. I had to cutout for the alternator and modify one hose on the passenger side and cutout for the rear on the drivers side. But it was all worth it !
Vette Fuel Rail Covers 1 (http://www.mnfbody.com/memberpages/pu12en12g/vettefuelrailfront.jpg)
Vette Fuel Rail Covers 2 (http://www.mnfbody.com/memberpages/pu12en12g/vettefuelrailclose.jpg)
Vette Fuel Rail Covers 3 (http://www.mnfbody.com/memberpages/pu12en12g/vettefuelrailside.jpg)
~ Black 95 Z A4 Convert~
P t ' s w e b p a g e (http://www.tc.umn.edu/~boatm005/)
Custom PCM, ASR PCM mod, 1st gear mod, short shifter, 3" CUTOUT, TB Bypass, ported/polished MAF, Vortech/K&N CAI, LT4KM, JET IAT, BMR STB, BMR SB, BMR SFC's, TPIS Fuel Pump (Ground-Control/Eibach ERS, BMR APHR, 160 stat, Ignition Booster waiting to be installed !)
[This message has been edited by pu12en12g (edited July 13, 2002).]
Calvin05
07-18-2002, 03:21 PM
I am planning on doing the same mod. Where can I get fuel rail covers that will fit my LT1? What is the best place to order them and all of the mounting supplies needed?
Some linkage and part numbers would be great.
BigBadBlack93Z: Did you put your on yet? How did it turn out? Any tips?
