chevy1963
01-26-2004, 01:36 PM
Does any one know if one sells a custom activation switch panel?
Activation switcheschevy1963 01-26-2004, 01:36 PM Does any one know if one sells a custom activation switch panel? Dean77 01-26-2004, 03:03 PM http://www.dynotune.org/store/Scripts/prodView.asp?idproduct=88 chevy1963 01-26-2004, 03:13 PM Thanks! but is their any thing cheaper then 150.00 ? Dean77 01-26-2004, 05:15 PM http://www.jimmy-jams.com/ Hawk 01-28-2004, 09:15 PM I like the NX switch panel the best, check it out. chevy1963 01-29-2004, 08:02 AM where does the NX one goes relative to the car? Zippity'Z 01-29-2004, 08:50 AM If you are asking about the activation switch ASSEMBLY, the kind you'll see here http://www.jimmy-jams.com/activationswitch.htm NX doesn't have custom assemblies......they only have a generic bracket that's a flat piece of metal you have to figure out how to bend it to make it work. *R Hawk 01-31-2004, 01:26 AM Here is my NX panel installed in my ashtray. Note that it is not designed to go in there, it requires careful modification via a dremel to get it to be perfect, :). http://www.eden.rutgers.edu/~bhawalka/switch4.jpg So, all this will tell you is yes this panel will work as shown, but you need to use common sense to get it installed. IMO, this is the most clean way for a nitrous setup. rskrause 01-31-2004, 10:04 AM Originally posted by Hawk Here is my NX panel installed in my ashtray. Note that it is not designed to go in there, it requires careful modification via a dremel to get it to be perfect, :). http://www.eden.rutgers.edu/~bhawalka/switch4.jpg So, all this will tell you is yes this panel will work as shown, but you need to use common sense to get it installed. IMO, this is the most clean way for a nitrous setup. I did the same with mine. Looks great, works fine. Rich Krause 97SS0594 01-31-2004, 02:18 PM i turned my convertabletop switch pannel into a custom switch pannel it looks nice ill get some pics and post them in a little bit!! | ||
