t-76 turbocharger
Old Jan 26, 2004 | 12:02 PM
Cody's Avatar
t-76 turbocharger
Does anyone know the best place to pick up t-76 turbo,intercooler and turbo headers for my 1995 Z28
Old Jan 26, 2004 | 12:28 PM
383WS6's Avatar
Originally posted by aggiez28
proturbokits sells a kit i believe. im doign a custom kit on my car so im not paying much attention to the kits out there.
inductionmotorsports can get you a good deal on just the t76 if you want t just the head unit.
i was gonna get the 76gts but went with an 88 insted
brook
Brook, are you buying Jordon's old kit?
Old Jan 26, 2004 | 01:22 PM
Cody's Avatar
thanks
Old Jan 26, 2004 | 10:56 PM
ProChargedWS-6's Avatar
induction motorsports is a great company to deal with. they might be able to help you with your turbo kit too.
www.inductionmotorsports.com
Old Jan 27, 2004 | 08:30 AM
Jesse_Boyer's Avatar
I concur. www.inductionmotorsports.com has some very knowledgable people who are always willing to help.
Old Jan 27, 2004 | 12:18 PM
mongse_1's Avatar
IM is Jeff Bromberger's company, right(had the LT1 Z running mid 9s)?
Hey Brook, just curious, how much was the GTS going to set you back? I'm looking at slapping a 76 or 88 on a tin can motor (LS1).
Old Jan 27, 2004 | 04:13 PM
Cody's Avatar
turbo's
If I can find some headers I think I'm going to put two HIFI 60-1 turbo's on instead of the t76
Old Jan 27, 2004 | 05:44 PM
SMOKNZ's Avatar
Good choice, those compressors fit a built 383 perfectly, there is a car going together in my garage right now with those turbo's
Bill
Old Jan 28, 2004 | 02:28 PM
JeffB_94Z's Avatar
Thanks for the support guys... I think a pair of SC61's would work extremely well in a twin application... you will have boost by the mid 2000rpms and potential for 1100rwhp...
of course, for max power, you can't beat a larger single...
the cost of twins will always be more than a single and in the case of a V8 you have plenty of cubes to spool the larger turbo, so i don't really see a reason to go with twins... but that's just my unsolicited 2 cents!
Jeff
InductionMotorsports.com
'94 Z28 9.56 @ 143 w/a 1.35 60'
Old Jan 28, 2004 | 03:06 PM
Cody's Avatar
turbo's
I am not a mechanic so if you could, can you tell me What will make the twin turbo set up more expensive than the single?Is it the plumbing? I can buy two new HIFI 60-1 turbos for $50 less than one t-76. I would really like to know because I have a few days yet before I am 100% commited to go either way, as I am waiting on the pistons and cam.
Old Jan 28, 2004 | 03:24 PM
JeffB_94Z's Avatar
there are a couple of factors to look at... first off, its not a fair comparison to take an "old school" dinosaur turbo like the 60-1 and compare it to a new PT76GTS... to make the comparison fair, you'd have to look at turbos that both have similar "genetics", namely - Garrett GT technology... the SC61 is a 61mm turbo that builds off of components from this family, as does the PT76GTS... in this particular case, 2 SC61s retail for $1550 and the PT76GTS retails for $1540... in this size range, the cost of the turbos themselves is a toss-up... the extra expense of the twins comes from the redundant items like two wastegates, two oil lines setups, two boost controllers, etc... and of course, more feet of tubing (although the tubing will be smaller diameter which is cheaper per foot)... though not a monetary cost, weight favors the single as well... two 61mm turbos weigh a lot more than 1 76mm turbo...
flip things around for a minute, what do twins gain for you? even if the cost was identical, why would you want more parts that could potentially fail? packaging isn't a good answer on a 4th gen f-body -- twins are a nightmare! spool is really the only advantage that twins offer over a single, and like i said, with a decent sized motor this is a non-issue...
of course, 1 or 2 turbos is about 100x better than 0 turbos, so either route is a step in the right direction...
Old Jan 28, 2004 | 03:27 PM
mongse_1's Avatar
You will need an extra wastegate and BOV for twins. The tubing does come into effect, although you will not have to make a crossover pipe like you would for a single.
Nice site Jeff. Hope everything's working out great.
Old Jan 28, 2004 | 03:30 PM
SMOKNZ's Avatar
The only real expence is one added wastegate, one boost controller can control 2 turbo's, you only need 1 BOV. Plumbing is cheap.
Start plotting airflow requirements on the compressor maps for varying boost levels on a 355 and a 383 and it will become apparent that the twin SC61's will put and keep airflow in the max efficiency range much better than the PT-76. The SC61's are the turbo's I picked for my project.
Bill
Old Jan 28, 2004 | 03:40 PM
Cody's Avatar
If twins spool at a lower rpm wont the driveability be better on the street using them.
Old Jan 28, 2004 | 03:46 PM
JeffB_94Z's Avatar
Bill,
the compressor maps for these turbos aren't even available to the public... PTE has signed an NDA with Garrett to get access to this info... even the dealers like us can't access the maps... and to say that all 76mm turbos are the same is like saying all 350ci motors are the same... the aerodynamics and materials that the wheels are made out of are extremely important... size is a key factor, but its definitely not the whole picture (especially since the size we're talking about is the inducer, which doesn't necessarily correllate to the exducer size)...
in any case, there is definitely in increase in efficiency with a single big turbo vs. two smaller twins... housing to wheel clearances stay roughly the same all all turbos, but for a larger housing, this becomes a smaller percentage and thus increases the efficiency... don't get me wrong, i'm not knocking twins, if you can pull it off in your budget then go for it... i just don't see it as anything worth paying extra for in this case... if you had a 2.0L motor and you were trying to make 1500hp, then spool would be the primary concern and twins would be worth any amount of trouble... but guys are running 101mm and larger turbos on 383ci motors, so i don't think a 76 is anywhere close to being "too big"...
Joe - thanks for the comment!
