Miles-
01-24-2004, 02:14 AM
I am throwing around the idea of buying this car (description below), I orignally wanted to get into my motor and do a heads and cam but this came up and for the money he is asking compared to whats in the car I am really thinking about it. I just wanted some opinions on the car. Obviously it has all high end parts on it and the only weak part i can see is the stock rear end. I live in cali so it will need to be smogged, of course the headers and ignition will be handled but what about the cam. its a custom blower cam smaller so i dont think it will be a problem. I am new to blowers and look at this as a learning project. I have been doing lots of reading and know how much money these setups can end up costing although it looks like most of the investment has already been made. Currently there are some header leaks, either intake or leaky valve covers and some venting needs to be done in the engine. I guess the fuel rails get really hot with the large fuel system.
here is the info on the car
Engine: 384 cubic inches, stroked and bored .035” and internally balanced
Block: LT-1 with splayed 4-bolt mains
Crank: Cola 4340 3-3/4”
Rods: Eagle H-beam 5.850”
Pistons: J&E forged blower pistons 9.1:1 CR
Heads: Ported LT-4 with Ferria stainless valves, Crane 1.6 roller rockers
Cam: Int. 224/.532, Ex. 232/.554, 115 LS
Ignition: MSD
Supercharger: Vortech T-trim at 11-12 psi
Oil: Melling Pump, Canton Pan
Flywheel: Centerforce SFI approved, neutral balance
Exhaust: Hooker long tube headers, coated, with O2 sensors,
Borla 3” cat-back , free-flow cats
Fuel System: Weldon 2015 with Dial-a-Flow and Weldon AFPR, dual filters and all lines replaced oversize with stainless braid. No in-tank pump.
Clutch: Centerforce
Transmission: Stock 6 speed with B&M Ripper shifter and urethane mount
Driveshaft: ACPT carbon fiber
Rear end: Stock with 3.42 gears
Suspension: Eibach Pro springs
Bilstein shocks
LG Subframe connectors and X-brace
LG shock tower brace
Hotchkis Lower control arms
LG torque arm
LG adjustable panhard
Rear frame boxed and welded
Shock towers welded
Brakes: Baer Track kit – 13” drilled and slotted front, stock size drilled and slotted rear, PBR 2 piston calipers (same as Corvette ZR-1)
Wheels: Forgeline RS forged aluminum 2 piece 17” X 9.5”
Tires: New BF Goodrich G-Force 275/40 17
Dynoed 536 rwhp and 506 ftlbs. on dynojet
let me here your issues, concerns, thoughts, views etc of the car. any input is appreciated.
thanks in advance miles
Ignition: MSD
Clutch: Centerforce
Bilstein shocks
LG torque arm
Shock towers welded
