Does the stock tunnel brace serve any structuarl purpose?
or is it jsut there to hold things up? I mean, the thing is easily bendable by hand, and is shaped like it there to keep the exhauist and driveshaft from falling down. If I took it off, would it hurt anything?
I had mine off for seven years with no ill effects.
-Chris
'95Z: Black; !AC, !EGR, !AIR, !MAF, !traction, !money, !sanity;
12.72 @ 109.84
'01 S10 Xtreme:White extended cab, 2.2L automatic; a mod or two...
Feel the Quickness
I gave her a stiff proposal, but she took it in the end.
-Chris
12.72 @ 109.84
Feel the Quickness
It doesn't have to be stiff in bending to be structural. It might be there to keep the tunnel from opening up at the bottom and compromising the tunnel's own stiffness. It would be primarily loaded in tension, so its bending stiffness/strength would not be important. Guess that makes it a secondary structural element.
Norm
'79 Malibu, way not stock (355, 5 speed, . . .)
'95 Mazda 626 V6 5 speed, not entirely stock either
'01 20th AE Maxima, 5 speed, stock (so far)
Norm
Look at what the tunnel brace mounting points are made of: spot welded sheet metal.
I've broken two of those bolts on my old 95z28 that hold the brace on the body.
The only purpose I could see is probably acting as a driveshaft safety mechanism if it were to break.
Steve
Steve
Doug Harden
29
Jul 30, 2003 07:05 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
