Got A Tick In My 99
Old Jan 21, 2004 | 07:40 PM
99TransAmWS6's Avatar
Unhappy Got A Tick In My 99
Cars stored for the winter..but went out and started it up today..to let her run..well after it warmed up..its got a "ticking" noise to it. I put my head to the engine..and it seems to be only on the drivers side. THeres no tick on the pass side. Took it out for a spin after it warmed up..and have no loss of power or anything..Car still runs strong. Any ideas? Maybe a half collapsed lifter or something?
Old Jan 21, 2004 | 08:02 PM
Mister Will's Avatar
I'm no mechanic but here goes. But it sounds like bent push rods you're describing. This would have happened as a result of a 3 - 2 shift or any other unexpected downshift. Then bouncing the engine off the rev limiter. Do you remember doing this before storing it?
I would also mention piston slap since your car was stored for the winter. But that should go away after warming up.
Perhaps we can get some more opinions on how to isolate the problem.
Old Jan 22, 2004 | 01:30 AM
tailwindxr7's Avatar
It could be something as bad as bent pushrods, or something as simple as a shot AIR check valve.
It's hard to tell based on what you've described...
Old Jan 22, 2004 | 10:56 AM
roadkillZ28's Avatar
same here in my 2000 z28, this is normal sound in LS1s engines.... after awhile the sound will disappear due to heat and lub oil...
Old Jan 22, 2004 | 03:27 PM
i to thought bent pushrods..but if i had a bent pushrod..im sure i could tell..the car runs, idles, drives, performs just the same. Ive talked to a few mechanics i work with..and they said youd know if you had a bent pushrod.
Old Jan 22, 2004 | 07:22 PM
MarcoZ's Avatar
I heard a"ticking" sound on my passengers side of the block and it turned out to be a bad knock sensor.
Old Jan 22, 2004 | 07:34 PM
howd you end up testing that out? cuz i only hear the tick on the drivers side. nothing on the passengers side.
Old Jan 22, 2004 | 11:28 PM
chpmnsws6's Avatar
could it be an exhaust leak? my leak cuases ppl to think i have a bad lifter (ppl that are new in the game) but the oldies always correct em
Old Jan 22, 2004 | 11:31 PM
Ex4.6Owner's Avatar
It's a belt.
Old Jan 22, 2004 | 11:33 PM
robb4964's Avatar
exactly what I was thinking
Old Jan 23, 2004 | 11:59 AM
MarcoZ's Avatar
There are two knock sensors, one per cylinder head, I took it to autozone and they connected it to their computer dyagnostics, and thats what it read failed passengrs side knock sensor.
Old Jan 24, 2004 | 12:15 AM
AL SS590 M6's Avatar
Moderator
The knock sensors are in the valley on an LS1, under the intake. NOT in the block on each side like an LT1.
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
Chris91Z
Mar 25, 2003 02:24 PM
