How long to change front brake pads?
firebirdjosh
01-21-2004, 06:24 PM
If the tires are off, how long to do it? And what specific tools do I need. Its freezing outside and I don't want to be screwing around. I already got horrible frostbite when my car got a flat a week ago. Thanks guys.
Zepher
01-21-2004, 07:08 PM
Should take just a few minutes,
It's 2 allen bolts,
http://www.transamws6.com/pics/01-2004/brakes.jpg
TheGreatJ
01-21-2004, 07:17 PM
Yep, 2 allen bolts, either 3/8" or 5/16" (can't remember offhand.) You'll also need a big pair of channellocks or a 6" or larger C-clamp to squeeze the caliper piston back into the bore. You can probably get it done in 15 minutes if the wheels are already off.
Z28James
01-21-2004, 07:40 PM
make sure you dont let the calipers hang :P i used a box to set them on.
firebirdjosh
01-21-2004, 07:43 PM
THanks guys. My brother has done this a million times but its too cold to ask him to do it. I am excited, new rims, lugs, tires, balancing, alignment and brakes. Hopefully it will feel even better!
Zepher
01-21-2004, 07:44 PM
I use small bungee cords to hold mine up.
firebirdjosh
01-21-2004, 07:57 PM
I use a jack stand.
aklim
01-22-2004, 06:19 AM
Bend a wire hanger and use that. As long as they don't hang by the hose. Do check the hose for cracks.
95NateZ28
01-22-2004, 07:48 AM
Might not be a bad idea to replace those rubber hoses anyways. New hoses are only about $12 and $13 dollars a side, but if you get them know that they are different for each side. You WILL need the bolt that holds the hose to the caliper though.
I put new rotors, seals, re-packed bearings, calipers, pads, and hoses on mine in just a couple of hours. Pretty easy job.
trackbird
01-22-2004, 09:15 AM
Working outside? I'd skip the hoses and bleeding for now. Get the pads on it and wait until spring (do a visual inspection, if the hoses are cracked, then it is time for new ones). And the allen bolt is a 3/8's allen (I use a 3/8 drive allen socket from sears or your parts store and a ratchet).
Stay warm!
aklim
01-22-2004, 01:16 PM
Skip the hoses and bleeding for now. When spring comes, get a set of braided steel hose. I did and it made the pedal a little firmer than it used to be. Not sure if it was because i had older rubber hose or whether it works better because there is less give in the hose.
TheGreatJ
01-22-2004, 02:00 PM
Agreed on the hoses. Don't mess with them in the cold unless they're cracked or falling apart. Then go to steel braided lines.
aklim
01-22-2004, 11:32 PM
I got the Earl's set and they are a 5 piece kit for under $100. One for each side and one in the center.
