Scott 97 Z28
01-20-2004, 07:54 PM
Just wondering how important it is to have an alignment done after lowering the car. I don't see what would change as long as you don't make any adjustments. Any input is appreciated.
Alignment after lowering- is it needed?Scott 97 Z28 01-20-2004, 07:54 PM Just wondering how important it is to have an alignment done after lowering the car. I don't see what would change as long as you don't make any adjustments. Any input is appreciated. Sam Strano 01-20-2004, 09:07 PM Both camber and toe change when you change ride height. Caster too, but to a much lesser degree. If you don't align it, you will destroy tires and it'll drive terribly. bruecksteve 01-21-2004, 05:22 PM Sam, does it move toward toe out when you lower the ride height? Sam Strano 01-21-2004, 05:58 PM Yep, the more negative camber you gain, the more toe out you get. Since you gain negative camber with lower height, the more toe-out you get. FYI, I changed my camber from -.7 and -1.1 to -1.2 and -1.6 the other day. My toe out went from 3/32 total out to (get this) 1-1/16" total out. bruecksteve 01-21-2004, 06:05 PM :eek: Is this the new ESP car? Coming down with cheater sway bars on huh??? :D Sam Strano 01-21-2004, 06:14 PM Originally posted by bruecksteve :eek: Is this the new ESP car? Coming down with cheater sway bars on huh??? :D ;) Yes, this would be a 2001 Camaro now mostly setup for ESP.... See you on the 14th! :D I'm coming down with EVERYTHING, every bar, rear springs, three sets of tires..... bruecksteve 01-21-2004, 07:34 PM You bringing S04's??? Sam Strano 01-21-2004, 07:39 PM yes bruecksteve 01-21-2004, 07:44 PM I still haven't seen the S04 price for a 315 on Tire Rack's site yet. Any idea?? (Maybe I should say "my" price! :D ) The V710's are $203 plus $15 for heat cycling. Sam Strano 01-21-2004, 07:52 PM I don't know that they are out yet. FWIW, I buy my Hoosier's from Tom @ Mid Atlantic Motorsport (574-243-5553). He busts his ass, and travels to most every big event. He also can deliver tires to events and mount them too. I'd recommend calling Tom, and even if you don't, I wouldn't spend money on heat cycling them. Just MHO though. bruecksteve 01-21-2004, 08:23 PM Why no heat cycling? Xscream 01-22-2004, 10:51 AM If your buying the 04's get them directly from Hoosier (unless you get a discount at Tirerack). The 04's are within 5 dollars of the 03's per Hoosier's pricing. I have always been able to get tires about 10-15 bucks cheaper from Hoosier directly than though Tirerack. The only thing that sucks is you can't get them heat cycled. | ||
