Suspension set up comparison.....
'01BlackZ
06-05-2002, 05:38 PM
I have been planning on getting the following:
Eibach Prokit, G2 LCA's,G2 relocation Brackets, G2 Adj. Panhard Rod.
however that will pretty much clean out my wallet. So i found the Level 1 suspension by SLP, which would be cheaper.
But, the G2 products seem alittle bit sturdier and in the end would give me a better setup.
So i'm debating whether or not i should spend the extra money. is it really gonna be worth it?
**Onyx Black 2001 Z-28 w/ GFX**
Performance Mods:G2 air lid, MAF, skip shift eliminator, Hypertech 160 Powerstat, free ram air mod,k&n filter, SLP Hi flow Bellows kit, SLP Air Temperature Module, Lou's Short stick, Corsa Premier catback.
Chassis/Suspension Mods: G2 SFC's, G2 3pt STB
Appearance Mods: RK sport carbon fiber letters/Z28 overlays & Nose Badge, Red Calipers W/ Black Brackets.My Z-28 (http://geocities.com/camarocket/main.htm)
94bird
06-05-2002, 11:27 PM
The Eibach springs are a good choice for a street driver, but please replace your shocks with a good set of Bilsteins valved for these springs. Shocks and springs are the best first step for our cars in my opinion. After that I'd go for subframe connectors, panhard rod, then shock tower brace. The stock sway bars are fine if you have the right spring and shock combination.
Mike Taylor
'94 Formula
Holley cold air, Borla downpipe, Walker UltraFlo catback, BMR STB, BMR PHR, Ground Control coilovers, Bilsteins, 16x9.5 Rikens, Hoosier 275/45/16 A3S03, G2 Torque Arm, Torsen T2R
[This message has been edited by 94bird (edited June 05, 2002).]
'01BlackZ
06-06-2002, 01:33 AM
<font face="Verdana, Arial" size="2">Originally posted by 94bird:
</font>
Honestly, i just want my car lowered so that it sits right on the 18" rims i just put on. the stock shocks will do for now, i already have the SFC's and STB. The panhard rod, LCA's and reloc brakets are coming with the springs.
blksgZ28
06-08-2002, 04:29 PM
you need new shocks with stiffer springs because the springs will kill stock shocks.
auto-Xer
06-10-2002, 10:10 AM
Your wheels wont tuck-up under your fender like they do on Hondas or BMWs really. I have G2 coilovers and the rear is as low as it can go, and its lower than the Eibach kit, but you can still see the top of the tread when standing beside the car.
