CGCBandit
01-19-2004, 07:00 PM
hello again...my question is, will a 1.6 rocker fit under the stock 87-up centerbolt head valve cover. I know you gotta but the special narrow body rockers, but will a 1.6 fit under there, or do I have to buy taller valve covers? TIA :D
jzajac1
01-19-2004, 07:47 PM
The GM (Crane) will fit but on some valve covers you have to slightly bend the baffle in the valve cover with a pair of channel locks. I've experienced a good fit on my 350 and on my son's 350 I had to bend the baffle slightly. Can.t explain the difference but they do fit....
aklim
01-19-2004, 10:19 PM
I don't think the height of the VC will make that much of a difference. You can grind the webbing away or get the crane gold RR in narrow body which will work very well. I did and am using the stock VC.
trackbird
01-20-2004, 01:04 AM
I used Harlan Sharp roller rockers under the Moroso centerbolt valve covers and they worked just fine. Those valve covers seem to have a little more room underneath then the stockers do.
CGCBandit
01-20-2004, 05:34 AM
Ok, thanks everyone.....this place is gr8 for info :cool:
