Adjusting TPS on a SD ECM
dj haf
01-19-2004, 04:28 PM
i heard you're not supposed to adjust the TPS voltage on a SD ecm. is this correct? if it isnt, what's the correct voltage to set it at? i know i need to use a DVM, but how should i check the voltage at WOT and what should it be at as well? thanks guys
aklim
01-19-2004, 10:15 PM
I believe it should be aroun 0.54V
90rocz
01-20-2004, 02:12 AM
MAF is .54 volts @ idle, 4.50volts @ WOT
SD is .70 volts @ idle, 4.50volts @ WOT
92BLKL98
01-20-2004, 06:42 PM
My '92 isn't adjustable. The older models had slotted a TPS but the '92 don't.
trackbird
01-20-2004, 10:58 PM
The '92 (and '91 I believe) will self adjust. They take the lowest reading they see and make it "idle" and go from there.
dj haf
01-20-2004, 11:30 PM
91 and 92 are both SD... would it be safe to say my TPS will self adjust since it's SD ('90) and that i wouldn't have to do anything to it?
aklim
01-20-2004, 11:57 PM
I would assume so. I knew the 91 and 92 are definately SD but I thought there were a few 90s roaming around that were MAF. I would bet that it would take the lowest value and assume that is the 0 deg throttle angle.
90rocz
01-21-2004, 02:01 AM
I always set my Idle (air bleed) first, then if I have to, use a small dril to lengthen the TPS mounting holes. Usually only modifying one hole is enough, and adjusting one hole(side) will enable you to get good readings.
I don't think they "self-adjust", they're just a variable resistor will a 5 volt reference voltage applied.
aklim
01-21-2004, 11:03 AM
They do self adjust from the standpoint that they take the initial voltage when you turn the key on to be idle.
