RSKrause Going from low lift 224xe cam to high lift? any real gain?
Highlander
01-19-2004, 01:51 PM
If im doing the head swap... Is it any real gain going from the low lift version of the cam to the high lift one that you have?
More or less how much? and where can I get that cam?
rskrause
01-20-2004, 06:43 PM
It's a "custom" order using lobes Comp Cams XE #3192/3196. The possible gain will depend on your head flow. The better your heads flow at high lift, the more of a gain you should expect.In general, you should see 10-15 rwhp.
Rich Krause
Highlander
01-20-2004, 07:47 PM
I thought it was going to be more of a difference.. the other question is: will the 116lsa help my idle better? and also widen the mid range??? It has a lot more lift at .200" so... there should be more of a difference...
Once I get my heads flowed I will post them here to let you know.
rskrause
01-20-2004, 10:05 PM
It will idle better and have more torque.
Rich Krause
