Zexel-torsen
Jake300win
01-17-2004, 05:51 AM
hey I have a quick question. I have a 94 TA with 273's so, i plan to buy new gears i want 3.42's so I will buy a take off dif from SLP but then will my ABS not work? I thought i read that some where on the board and, i fit will not work is thair any way to fix it.
Jake300win
01-17-2004, 03:35 PM
anyone.
Capn Pete
01-17-2004, 03:56 PM
AFAIK, there are two styles of rear ends:
- one which supports having ASR (traction control)
- one which doesn't support traction control
A diff without ASR has a speed sensor mounted on top of the gear pot that reads off a reluctor wheel (I think that's what they're called??:think: ) on the carrier inside.
A diff with ASR doesn't have that sensor on the gear pot, but instead has a sensor on the end of each axle tube, and each axle has a reluctor to tell the computer the car's speed.
When you order the rear end, I think you will just have to specify whether or not your car has traction control, so they will send the correct style for your car. Also, I think I heard there's a difference in the length of the axles from LT1's to LS1's, so make sure you specify the year as well;).
Jake300win
01-17-2004, 04:08 PM
Thansk for the info... I dont have traction control.
