28" ET streets
GS355
01-15-2004, 10:15 PM
Has any put these tires on there car and if so are there anyproblems or things I need to do to modify my car to make them fit good.
GS355
:confused:
RacinLT1
01-16-2004, 12:02 AM
do a search in drag racing,this has come up many times. most of the time there is major hammer work on the inner fender involved,some trimming of the fender lip depending on size,and possible bumper trimming.
limige
01-23-2004, 02:18 AM
bs, depends on how wide.
i ran 10.5x28x15 et drags on mine just fine. just use adjustable lca's to center it in the wheel well.
GS355
01-23-2004, 06:20 AM
Thanks Guys for the replys. I haven't had much time to do testing with that big of a tire yet do to a broke spec stage 3 clutch. Just got my street twin it and have to get it balanced to neutral.
GS355
limige
01-23-2004, 05:51 PM
what happened to the clutch? i was thinking about trying the stage 4...
GS355
01-23-2004, 06:33 PM
The thing came apart on me at the track. A while back There were a few of these clutches that seemed to come apart within 2 weeks of each other. Me and a few friends thought we got lucky then on of theres came apart. It's been a about 3 or 4 months since I've heard of any of these clutches coming apart. But now mine took a dump. But I beleive it's been a good clutch over all. But I'ld recommend stepping up to a street twin if the cash is there. I've seen a few of them floating around for a good price.
anyways thats what happened.
GS355
SABLT194
01-24-2004, 06:44 AM
What gears are you going to run with that 28" tall tire? Unless you have some really deep gears or gobs and gobs of low end torque, you might be in serious bog territory with that M6. I tried running a 27" Hoosier with 375 RWHP and 4.10's and that was too much tire so I dropped back to 26 ers again. All that being said, my car is super heavy (3750). If yours is a featherweight, you might just get away with it.
Steve
GS355
01-24-2004, 03:49 PM
Steve
I think I have enough HP & Tq( 383 T trim w/aftercooler)10# of boost , with 75 shot that I haven't got to use yet :D ). Plus I'm not getting all the boost I should be getting, My BOV is leaking. I should be seeing 3-4 more # of boost. I'm running 3.70's with a locker, 35spline axles, BMR track pack, tubular K member, and a pileof other stuff. Don't feel like typing any more of the mods, anywho. I think I have enough low end torque.
GS355
SABLT194
01-25-2004, 06:11 AM
Uh, Yep I'd say with your goodies you will not be under powered at launch. :eek:
Later
Steve
