InjectedSS
01-14-2004, 09:34 PM
Whats the deal, this program doesn't work worth the crap :mad: Unless Im doing something wrong which I can't seem to think I am.
I enabled speed density in the switch table. Have my MAF removed. Logging with datamaster, the Short Term BLMS are at like 80, subtracting a $hit load of fuel.. I log like a couple of minutes of data with the car idleing in closed loop, run the file thru ve master and it shows that it didn't change crap in the little log :mad: What the Hell? It should have lowered the numbers a ton, but it did nothing..
What's the deal?
Sean94Z
01-14-2004, 09:37 PM
When I used it, I had to use with a lot of logging, like 10-15 minutes of driving, then do it..
--Sean
Dan K
01-15-2004, 12:16 AM
I'm pretty sure VEMaster will not alter anything that occurs in cell 16.
Just do the idle stuff by yourself. Get it sorted out and then take a 20-25 minute log of part throttle and run vemaster on it. Usually 2 or 3 times is enough to get you close. Then just go in and look at the 2 ve tables and make sure that the cells seem go "flow" or are somewhat linear...meaning that the values get higher as map and rpm increase.
InjectedSS
01-15-2004, 12:28 AM
Ahhhh that makes sense... Cell 16 being the idle cell :D
Thanks dude, you da man :thumb:
MentalCaseOne
01-15-2004, 09:29 AM
I am so lost here. My car idles with Block Learn cell 1.
are Block Learn Cells the same as the ones you mention in your
post?
Marvin
InjectedSS
01-15-2004, 06:39 PM
post?
Marvin
Not sure what your asking, but your car should ALWAYS idle in cell 16. I don't know why it wouldn't be in that cell if you say it isn't. What are you using as far as scanning goes?
MentalCaseOne
01-17-2004, 05:02 PM
AutoXray EZ-SCAN 6000 their top of the line scanner with software recently updated to their latest.
Marvin
