LCA and AFCO LCA Bushings
Tom 97ss #25
01-12-2004, 09:10 PM
Has anyone atempted to use the AFCO / stock car racing products or similar LCA bushings on a stock Rear LCA?
http://www.secureperformanceorder.com/afcostore/getproduct.cfm?CategoryID=8&ClassID=113&SubclassID=532&ProductID=790
http://www.stockcarproducts.com/susp1.htm
Based on my measurements on my stock Rear LCA this would fit.
1.90 OD 2.375 Length 1/2 inner diamiter
At $14.00 a pop this would be a hell of lot cheaper that Global west bearings or similar setups plus the stock RLCA has no welds to break.
Thoughts?
Norm Peterson
01-13-2004, 06:38 AM
Those pieces are for the front suspension only, where the suspension arm motions can be accommodated by a cylindrical sleeve (IOW, the only rotation is about a single axis).
Rear LCA's need freedom of rotation about all three axes, not just one, so you need some sort of ball boint (read: rod ends).
Norm
