What is my motor's nitrous LIMIT???
Old Jan 12, 2004 | 07:37 PM
96YenkoClone's Avatar
I am running a 383 10.8:1 with a SCAT 9000 crank, sealed power hyper pistons with coated skirts, stock pm rods, M6 with 3.42 gears, if you guys need any further info to give me an educated answer just let me know?
Old Jan 12, 2004 | 10:53 PM
n20ta2's Avatar
I wouldnt run over 150 hp with those pistons, you may get away with 175 with a super conservative tune but the extra 25 hp isnt worth it. What are your ring gaps and did you debur your piston tops and combustion chamber?
Old Jan 13, 2004 | 08:51 AM
not sure my ring gaps off hand but yes everything is clean inside the chamber
my motor from top to bottom is a ported lt1 manifold, fully ported 63cc lt1 heads with 2.00/1.55 cc305 with full comp cam valvetrain, 1.52 roller, scat 9000 crank, sealed power hyper pistons, stock rebuilt PM rods, 30# inj, 52mm tb, high pressure oil pump
Old Jan 13, 2004 | 12:23 PM
WS6_Keith's Avatar
I'd probably stop around 150-175rwhp. Make sure to tune it with a wideband O2.
My stock bottom end took 180rwhp shot for quite some time before expiring due to a faulty fuel solenoid. With a 92 n2o jet, that should be around 225 at the motor.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
JamesN1830
Sep 11, 2002 10:57 AM
