Jabberwocky
01-12-2004, 07:51 PM
I just began noticing that the inside rear tire squeaks while cornering hard. Does this mean my LSD is worn? BTW, how do you tell when the LSD is out and when it isn't?
I'm not too familar with cornering physics, but am I right to assume the inside rear is suppose to lose traction before the outside rear because the weight shifts outward. So would this be normal then? Also, I'm still a novice at this, so have I hit the cornering limit of my car or is there more? I know sliding the rear around is slow, but it felt like there's plenty of grip left on the front while the rears were running out. If I had push harder, i'm pretty sure the outside rear would be the next tire to start slipping.
PS my car is an lt1, so I got an auburn.
