rje
07-14-2002, 02:36 PM
It's in the sig. Definitly be in the 10's by the in of the year.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
Randy
