eagle stroker and small base circle.
Kyle@CSS
01-10-2004, 06:59 AM
I built a LT1 383. The guy that did my machine work said I would need a small base circle cam. I had comp cam build on a custom small base circle cam. Its a nice cam. But I decided to put a regular small block in my Z28. Its already got a cage in it. And Im making it a pure race car. I also have a 1994 yellow formula. The engine started knocking. Im going to put my stroker engine in it. Im going to downsize on the heads and cam. I m wanting it to be alot more streetable. Can I just get a off the shelf cam? Or does it need to be on a small base circle also. Its the 4340 crank 3.75 stroke, and h-beam 5.7 rods. Im also going to need another set of heads. These heads arent what Im wanting to use everyday. But I need to know about this cam asap. So I can get this done. Im leaving my wife with out a ride seince we only have the tahoe running.
jay g
01-10-2004, 10:15 AM
i have the forged eagle 383 crank, eagle h beams, and a standard cc 503 cam with no clearance problems with the cam
Kyle@CSS
02-05-2004, 08:00 PM
Anyone else.
SStrokerAce
02-06-2004, 12:28 AM
With MOST 383's you don't need a small base circle cam.
At least on a Eagle H Beam setup.
Bret
racer7088
02-06-2004, 12:41 AM
Depending on the rods you have you may or may not need a small base circle cam and/or you will also need to clearance your rods.
Kyle@CSS
02-06-2004, 07:13 AM
I already have the engine in the car. I have a cam with asmall base circle now. Im wanting to change it. I would hate to buy another cam that I cant use.
bkrepindy
02-06-2004, 08:31 AM
I have an Eagle rotating assembly: 4340 Crank and 6" Rods. I used a standard base circle cam (Crane) with no problems.
SStrokerAce
02-06-2004, 01:22 PM
You don't need to change it, you can still use that one but a small base circle cam is NOT required.
Bret
Kyle@CSS
02-06-2004, 06:52 PM
My cam is on a 110. Comp cam built it that way. Im spraying 150 or more. SO I need to change it.
