Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
SLP long tube special with cats or offroads
Old Jan 9, 2004 | 07:28 PM
tbyrne's Avatar
A complete package is available for as low as $912.00!
Headers
SLP was the first in the industry to release tuned length long tube headers for the LS1 powered Camaro* and Firebird*. The length of each header tube was calculated to maximize exhaust scavenging. The headers' tuned tube lengths use exhaust pulses to create a vacuum in the collector. This vacuum pulls exhaust gases out of the cylinder making more room for a fresh air/fuel charge. The more efficient exhaust scavenging lets the engine rev faster and produce more torque and horsepower.
NEW (part # 30049) For those F-Body owners who wish to remove their factory EGR valve (1998-2000 models only) and air-pump assembly, SLP now offers this revised long-tube header package. These headers are functionally identical to their original tuned-length LS1 long tubes but lack the stock emissions-equipment provisions. Removing these items and their attendant hardware reduces weight, frees up under-hood space, minimizes the likelihood of exhaust leakage, stops annoying check-valve clicking, and makes for a cleaner appearance in the engine compartment.
You will see increases of up to 41 horsepower and 58 lb. Ft. of torque! Equal length headers work well but, SLP tuned tube length headers are the ultimate! SLP's new headers are built with stainless steel 1 3/4" primary tubes that flow into a stainless steel, 3" collector. The headers have quality OE flanges and are completely compatible with the stock EGR, oxygen sensor and air pump systems. To connect the headers to your complete "back to the bumper" or other SLP exhaust system, SLP has designed a unique new stainless steel 3" y-pipe to work specifically with these headers. This pipe is included with the headers. To use the y-pipe you must have our optional high flow catalytic converters (31037). NOT legal for use on pollution controlled motor vehicles.
* Convertible with automatic transmission requires kit 30054 & 30055.
SLP LS1 Stainless Steel Tuned Length Long Tube Headers:
Give up 1/2 second reduction in 1/4 mile ET and increase trap speed by up to 5MPH
Have easy, bolt-on installation
Compatible with all factory emission equipment
Improved 0-60mph and 1/4 mile performance
Are .055" wall thickness 409 stainless steel tubing, mandrel bent to assure free flow and long life.
Polished aluminum-ceramic thermal barrier coating keeps heat in, exhaust velocity up, and underhood temperature down.
Limited Lifetime Warranty
Installation kit
To help make your header installation easier, SLP offers these installation kits complete with all gaskets, bolts, fire sleeves, clamps and brackets that are required for your specific application. detailed installation instructions are included. Individual components are available separately.
Highflow cats
These catalytic converters were chosen after much research and testing for use with our long tube tuned length LS-1 "F" car headers due to there low restriction and small size. sold as a set of 2.
Sale pricing is -
30049 1998-'00 SLP long tube headers/Y-pipe - w/o A.I.R. & EGR fittings $659.99
30051 1998-'99 SLP long tube headers/Y-pipe $722.99
30052 2000 SLP long tube headers/Y-pipe $722.99
30053 2001-'02 SLP long tube headers/Y-pipe $722.99
30054 SLP installation kit $101.99
30055 SLP installation kit for convertibles $118.99
31037 SLP cats $297.99
racepipes T BYRNE Motorsports race pipe package for SLP headers (includes 02 simms) $149.99
Shipping is FREE in the continental 48 states.
You can include the T BYRNE Race Pipe Package for $100. when you order it with a complete header, Y-pipe, installation kit and cats package!
Just note these sale prices when you place your order.
Tom
transam_388
Mar 15, 2015 11:53 AM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
NED4SPD
Sep 16, 2002 10:45 PM
