cell-specific low BLMs
Old Jan 9, 2004 | 11:06 AM
ryaskovic's Avatar
I was going to run some tests to determine for myself, but figured I'd ask here first. In closed loop, part throttle cruise, BLMs cells 6&7 will sink to 109-111 range. All other cells will stay in the 122-128 area. Idle is right at 126-128. Could timing cause this? FYI, that's with stock injectors, stock constant, stock offsets but on a 383 LT1 with a <currently> pcmforless tune.
Let me add that the BLM boundaries are stock, as are the MAF and MAF tables.
Thanks,
RobY
95Z28
Old Jan 13, 2004 | 04:55 PM
quicksilver97ta's Avatar
With low blm's your PCM is reducing the amount of fuel the MAF thinks the engine needs. You could try cleaning your MAF and/or look at your data log where you noted the low blms. On the same rows (same run time), note the grams/sec your MAF is reading. You want to reduce those values slightly in your MAF tables (to tell the PCM that less air is actually flowing thru the MAF at a given hertz, that way it will give it less fuel). It will be trial and error to target a 128 blm.
Hope that helps.
Old Jan 13, 2004 | 07:17 PM
ryaskovic's Avatar
Hope that helps.
I've thought about that and I've cleaned the MAF. At this point, I'm not convinced I want to tweak the MAF tables though.
Old Jan 19, 2004 | 12:10 AM
sweetassz's Avatar
I agree, tweaking maf table alot of times just masks a problem. Make sure your injector size is correct. I had the exact same problem or so I thought, I have a 383 with 30 lb svo's, I bumped my injector rating to about 32.5 dont remember exactly but this cleared it right up. Also this was after many data logs, and tweaking of maf table.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
