WhiteBeast
01-08-2004, 11:03 AM
Ok, I installed my PAC-OEM1 in my car for my stock Monsoon stereo. It has preouts for both front and rear RCA outputs. I was just wondering how i would go about hooking up my amplifier with the RCA outputs.
When i do have my subwoofers going and change the balance from center to all the way to the left, then the subwoofers sound a lot louder. More thump...
So did i hook it up wrong or should i change where i connected the RCA cords for the amplifier. I hooked the RCA cables from the amplifier to the rear outputs for the PAC-OEM1.
LS1 RULZ
01-08-2004, 11:51 AM
How old is your OEM-1 and where did you get it? They had a wiring error from the factory at one time where the balance control would not work right. There was a post about this awhile back in the electronics forum at LS1.com
LS1 RULZ
01-08-2004, 12:01 PM
From the LS1.com post....
As some of you know, the PAC OEM-1 has had problems with the REAR outs being summed to mono some where along the signal path. Karl from PAC gave me a call a couple of days ago to discuss my problem and he just posted this fix, or you can take a look here for a diagram of the fix:
http://www.go2pac.com/pdf_files/mis...%20bulletin.pdf
Hi guys, just looked at a vehicle today and found the problem of the rear outputs of the OEM-1 not balancing. Our ADD-GM21C cable was made incorrectly. The two rear negative inputs to the OEM-1 have been switched. We will let our supplier know of the problem and future shipments of the ADD-GM21C cable will be corrected.
We will have a bulletin posted the first part of next week that will explain how to fix the wire harness.
If you guys are technical, you can just cut the grn/blk and purple/blk wires in half just before the 18 pin molex connector, but leave enough ***tail so you can solder/butt splice it to the opposite wire. Without a pin extraction tool, it will be impossible to remove the pins without damage, so just cut and resplice oppostire wires. If you did not understand what I meant, then wait till the bulletin gets posted on our website.
We apologize, and hope you will continue to recommend and use our products.
Thank you,
Karl
WhiteBeast
01-08-2004, 07:20 PM
Ok, I found out that its not just the left side balance that increases the subwoofer loudness. If i transfer the balance to the right side as well they get deeper.
So right now i am trying to figure out the correct way to wire them up...As of right now i have the RCA outputs coming from my Brand New PAC-OEM1 unit into my amplfier. Then from there i have a dual 10' subwoofer system with dual voice coils. So i have 4 outputs on my amplifier (L+ L- R+ R-)
In my instructions of my amplifier it says that i can bridge the amp, but it only has a picture of one subwoofer hooked up. And the connections are connected to L+ R-. So what about the other 2 connections? Would i do the same for the other subwoofer?
LS1 RULZ
01-08-2004, 07:38 PM
NO. When a 2 channel amp is bridged ALL subs are connected to the L+ and R-
WhiteBeast
01-10-2004, 01:25 PM
OK, I found out my problem. I reversed the current on one of the subwoofers. My subwoofer layout is that i have dual 10" subs, but one is reversed, and the other one is pointing forward. They are in a plexiglass enclosure, so i guess they were just cancelling each other out.
Now they are so freaking loud they actually rattle every body pannel on my car.... But i dont drive around with them up that loud... :-)
Thanks guys
