FS C5 Rocker Rails
Old Jan 7, 2004 | 01:40 PM
TAZ28's Avatar
FS C5 Rocker Rails
A & A Corvette
Designed to protect your body work from "high center" situations like this. Check the underside of your rocker panels. If they show signs of scraping - you NEED these!
Made of T6061 Aluminum, these rails mount just inboard of the rocker panels directly to the frame. Your rocker panels are now protected from unsightly and expensive damage. Counter sunk on the top side to clear factory rivets and bolt heads and on the bottom so the stainless attaching bolts are flush. The front is also slightly curved up to follow the contour of the frame and to eliminate the chance of catching the end on any obstacle. A " Must Have" on any C5 and a perfect compliment to our frame savers. Simple bolt on installation
Never installed
See pictures at https://www.aandacorvette.com/cart/s...sp?MainCatID=5
$65 you save a few dollars and the shipping if picked up.
I will not ship these it costs to much. Either pick up or make arrangements to meet somewhere. If you know someone in the Austin area that travels between you city and Austin and can convince them to pick them up that is ok.
Ray
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
LT14LIFE
Nov 15, 2015 06:22 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
alliance12364
Sep 17, 2015 08:43 AM
