Gripenfelter
01-07-2004, 12:51 PM
I need a part # for this Comp Cams cam:
Comp Cams Xtreme RPM grind
.563/.563 Dur@.050: 224/224 LSA: 112
Part # for 224/224 camGripenfelter 01-07-2004, 12:51 PM I need a part # for this Comp Cams cam: Comp Cams Xtreme RPM grind .563/.563 Dur@.050: 224/224 LSA: 112 Gold Z 01-07-2004, 05:22 PM That is the TR224 cam. You can find specs, pricing, and even dyno sheets for the cam at http://www.thunderracing.com/. That is probably the best all around cam you can put in a LS1. It's been the cam that all others have been compared to. Excellent choice! Gripenfelter 01-08-2004, 11:57 AM So this cam is only available only through Thunder? Gold Z 01-08-2004, 11:24 PM No. Others have copied it or very slightly altered the specs. It is a Comp grind so you could also order it through them. I personally find it better to buy from the vendors who support this website. Customer service counts a bunch and Thunder Racing is one of the most respected companies around that specialize in LS1s. Demon SS 01-11-2004, 07:47 AM The Comp Cams lobes numbers are 3715 for a 224 duration at .568 lift so you would ask for that lobe number on the intake and the exhaust and pick your LSA and I usually set our cams up at +2 advance. The difference between .563 and .568 lift is minimal. | ||
