Rear end question
SS Pat
01-05-2004, 09:27 PM
I've noticed lately that when doing a turn the rear end of the car seems to almost slide side ways to the outside. I don't mean spinning out, it's like the rear wants to slide of the rear axle while the inside kinda pushes over. It's more noticeable in left hand turns being that it's a wider radius. The only suspension mod is Eibach prokit springs, but they've been on since 17k miles and it went some time before this showed up,the car now has 48k. Could it possibly be the stock shocks are worn out. I was thinking of installing a set of Bilstiens, I'm not looking to do any autox just want the car to ride better. Any ideas? Thanks
bruecksteve
01-05-2004, 10:20 PM
The stock shocks are not good to start with and then they wear out after 30K miles. That's the first place I'd start. Good shocks on a F-Body make ALL the difference in the world. Some Bilstein HD's would be great.
BigRich
01-06-2004, 03:29 PM
you didn't say what kinda tires you got
like steve said, your shocks are prob dead too
also, your auburn limited slip is probably shot and you have no limited slip ability. that's what happened to mine. just posi all the time. i swapped in the SLP take off torsen and it made a big diff. shoulda got the T2R though
bruecksteve
01-06-2004, 04:47 PM
Yep, can't wait until my T2R gets here. I think Sam is holding it up so I won't intimidate him when he comes down here in February for the Pro Solo... :p :bs:
TA Dreaming
01-07-2004, 07:54 PM
make sure nothings loose first. a part my have works itself loose. never know. and if your car has the level two suspension you already have bilsteins on the car. do you know if its a level two car?
Ken S
Thats what I was feeling on my stock shocks at 40k miles.. Feels kinda like just the axle is flopping inside the body.. Replaced the shocks and it disappeared.
