Trick Flow LT1 Heads
OUTCAST
01-04-2004, 03:39 PM
Aluminum Cylinder Heads for Chevy LT1
• Designed for supercharged,
nitrous and stroker applications!
• 195cc intake ports, 75cc exhaust ports
• 64cc combustion chambers
• Use stock sensors and fittings
• Assembled heads include 2.02" intake/1.60" exhaust stainless valves,
valve springs, retainers, locks, guideplates and 3/8" studs
TFS-30400010 Assembled heads, pair
TFS-3042B010 Bare castings, pair
Has anyone heard good or bad about them. Our would you got to LT4 heads thanks in advance!
amean94ta
01-04-2004, 04:01 PM
never knew trick flow made lt1 heads but dart just came out with a sweet pair that are susposed to put the afr's to shame. saw them at the pri show:D
marshall93z
01-04-2004, 04:18 PM
for the lt1? that would be nice...
SStrokerAce
01-04-2004, 05:37 PM
http://www.trickflow.com/media/pr/pdf/Newproduct_page1.pdf
These look like a better alternative than the AFR's especially if they have them in stock. Well at least they are going to be better for porting out of the box they are probably not going to beat the 195 out of the box AFR's
The standard 23 deg SBC Trick Flow heads flow:
0.100 50.6 57.9
0.200 135.8 98.3
0.300 191.0 136.4
0.400 229.7 162.9
0.500 253.1 176.9
0.600 254.3 189.6
Not gang busters but at least AFR doesn't have a lock on that market, or it will help them refine the LT heads over there so there is not a 8 week wait on them.
Can't find anything on the Dart ones.
Bret
DarthIROC
01-04-2004, 06:55 PM
0.100 50.6 57.9
0.200 135.8 98.3
0.300 191.0 136.4
0.400 229.7 162.9
0.500 253.1 176.9
0.600 254.3 189.6
Bret
How does that compare to LT4 flow numbers?
Im sure i could find numbers in a search, but Im going out and thought maybe, like this I would have an answer waiting for me when I got back :lol:
Injuneer
01-04-2004, 08:27 PM
There are already threads on "LT1 Tech" discussing the Trick Flow heads. Might want to just join in on one of those threads.
