94Sleeper
12-30-2003, 09:30 PM
I have been experiencing oil pressure problems above 4000 rpm which seems to be a relativly common problem on some rebuilt motors. I contacted Nick at Nutek and he told me that they run a lot of stock pans with Melling pumps with no problems. He did tell me that the Melling pumps they install on LT1s are M1055 not the M55 (which is what I have). He told me the M55 pump has a larger diameter but he honestly did not know why it would cause a problem. He also told me to make sure the pickup height is correct.
Well the pan is off and I checked the height of the Melling pumps pick-up and it was about 1 inch off the bottom of the pan. I installed a new blueprinted OEM pump (white spring) and its pick-up is currently sitting about .825" off the bottom of the pan at the mouth of the pick up and about .650" at the rear (see the photos of the clay Clay1 (http://mywebpages.comcast.net/khartnett232402/images/Clay1.JPG) Clay2 (http://mywebpages.comcast.net/khartnett232402/images/Clay2.JPG) ). Nick said that he sets them up so the pickup is .250" - .375" off the bottom of the pan. I am guessing that I need to drop this pickup almost .400" to get it set right. Is this the correct height and does anyone else have any experience setting the pick-up height?
