working with vinyl
joshp14
12-29-2003, 02:00 AM
Wasn't sure where to put this so I'll ask here.
I have a few questions on working with vinyl.
How would I form vinyl over lettering like this w/o getting wrinkles? How should I make the letters...and how should I make the vinyl stick?
I want to make a box like this for amp display.
http://home.austin.rr.com/linkless/large/DSC00992.JPG
But instead of having the WS7 emblem there, I would rather have the 3D effect lettering there....something like this....but obviously smaller.
http://www.subthump.com/images/subthumpboxes/ta02.jpg
All help is appreciated.
Josh
LS1 RULZ
12-29-2003, 07:14 AM
I use 3M adhesive spray (High Strength 90, NOT the Super 77) to attach the vinyl to the guitar speaker cabinets I build. Here's a 4x12 cabinet I just built and wrapped in vinyl.
http://pic5.picturetrail.com/VOL83/511092/2909744/39611980.jpg
To do lettering would require some good contact cement and a heat gun to help form the vinyl around the letters.
joshp14
12-29-2003, 12:35 PM
So would I need to strecth the vinyl at all? or just adhere it down? Also, on the lettering, would I apply the cement to the back of the vinyl first, and then use the heat gun, and then press it down? or would i even need cement on the letters?
LS1 RULZ
12-29-2003, 12:58 PM
The only stretching you need to do, if any, is when going around corners and stuff.
You put contact cement on both surfaces. Wait a while for it to tack and then press the pieces together.
joshp14
12-29-2003, 02:36 PM
How do you keep it from wrinkling/creasing when going around corners and such?
LS1 RULZ
12-29-2003, 02:47 PM
Contact cement. Once the two surfaces are bonded together they aren't going anywhere.
joshp14
12-29-2003, 07:16 PM
Any ideas on what I can use for the letters?
notstock4long
12-31-2003, 04:22 PM
Use the heat gun to keep it from wrinkling. If you use the heat gun, you can stretch it, therefore keeping it from bundling up and wrinkling.
megabass
12-31-2003, 07:41 PM
Also, you don't want to stretch it too much, you'll skew the grain and it will look bad. That's why I don't mess with the stretchy kind of vinyl.
joshp14
12-31-2003, 09:32 PM
Thanks guys. I will keep that in mind. I just did a practice for the lettering. I cut out the letters with cardboard and then glued the cardboard to another piece of cardboard. It turned out really well. Hopefully I can get the same turnout when I do it again.
