94TA_LT1
12-26-2003, 10:56 PM
Anybody know if a LT1 crank will fit in a 96 chevy vortec 350 truck motor
Crankshaft94TA_LT1 12-26-2003, 10:56 PM Anybody know if a LT1 crank will fit in a 96 chevy vortec 350 truck motor SStrokerAce 12-27-2003, 05:20 AM yes, both a 1 piece rear main seal cranks. Just make sure you check the balance on them. Bret 94TA_LT1 12-27-2003, 06:39 PM what do you mean by check the balance? the balance of the crank? 94TA_LT1 12-28-2003, 12:38 AM Anybody else know what he was talking about? Turbo6 12-28-2003, 12:19 PM The crank balance has to be checked...ie, if the crank is externally balanced in the rear by using a weighted flexplate/flywheel (as they come from the factory), either you have to balance it using a counterweighted flywheel/flexplate or internally balance the rotating assembly and then match it with a neutral balance flexplate/flywheel. Though, if you are going to be building a whole new rotating assembly w/ fresh pistons/rods it will need to be balance anyway, so just make sure you have the correct flywheel balance to match. | ||
