tooljunkie
12-26-2003, 07:28 PM
Are Jesel shaft mount rockers worth more hp over stud roller rockerstooljunkie 12-26-2003, 07:28 PM ? cnorton 12-26-2003, 07:54 PM I believe that the benefits of pedestal mount rockers over stud mount units are typically seen when high (500# plus) spring pressures, high RPM (7500 +), and extreme ratios (1:8 or 1:9) are involved. A rocker arm is nothing more than a lever that transfers and multiplies the motion that is begun by the camshaft. Making that lever more efficient and more stable will pay dividends when the engine is operated at levels exceeding the ability of the stud-mounted rocker systems to maintain their integrity. I guess it comes down to how you plan to use the engine, how much money you want to spend, and how much it's worth to pull off the valve covers to show off your valve train components. LameRandomName 12-26-2003, 08:08 PM Well, Smokey said that anything you can do to increase valvetrain stability is worth HP. SStrokerAce 12-26-2003, 08:13 PM A shaft mount rocker has the advantage of stiffness. The stiffer the parts the less deflection in the system. You normally find this as an advantage in setups were the cam lobe is very agressive. I.E. Solid Roller lobes. Any deflection in the system, thru weak studs, weak rocker arms, weak pushrod will cause the valve not to open as much as the lobe wants it to open, basically keeping it away from the optimum lift curve that the lobe wants. So the stiffer the system the more the valve opens. So the shaft mount rocker helps take the deflection out of the system by removing the rocker stud. One reason why high rocker ratios are only found on shaft mounts is because the shaft mounts can handle the increased loads that the rocker ratio puts on the system. A 500lbs spring pressure on a 1.5:1 rocker is 750 lbs on the pushrod end while with a 2.0:1 rocker has 1000 lbs on the pushrod end. It might increase the lift on the valve side of the equation but it also increases the spring pressure on the pushrod side of the system at the same rate. Hope that helps, Bret JWINN 12-27-2003, 02:07 AM A power secrete most people over look is pushrod technology. I will tell ya this for fact if you can get a big enought diam pushrod that will not deflect and isn't to heavy in return will in fact net you power gains. I know this because I seen it produce results well worth the money for the pushrods on the dyno. OldSStroker 12-27-2003, 08:00 AM Originally posted by JWINN A power secrete most people over look is pushrod technology. I will tell ya this for fact if you can get a big enought diam pushrod that will not deflect and isn't to heavy in return will in fact net you power gains. I know this because I seen it produce results well worth the money for the pushrods on the dyno. Yep, stiff pushrods are very important; the higher the loads the more important. Pushrod loads don't just come from high valve spring pressures. The acceleration of the valve train plays a big part. Remember F=Ma. Cams with fast accelerations combined with high rpm and high spring pressures lead to some exotic pushrods in high end engines like Cup and Pro Stock. Double tapered shapes, large (1/2 in) diameters and some exotic metals are all used. There are speciality pushrod manufacturers whose names are not household words to many of us but certainly are to the high-end engine guys. Hot Rod Hawk 12-27-2003, 08:56 AM Originally posted by OldSStroker There are speciality pushrod manufacturers whose names are not household words to many of us but certainly are to the high-end engine guys. Trend pushrods! LameRandomName 12-29-2003, 09:30 AM About 20 years ago I recall that some company was experimenting with Carbon Fiber pushrods, trying to get light weight and great stiffness. Anyone know what ever happened with that? OldSStroker 12-31-2003, 10:24 AM Originally posted by Hot Rod Hawk Trend pushrods! Them, too. ;) OneFlyn95z28 12-31-2003, 03:54 PM I ahve always had good luck with Smith Bro's rods. It has been a while. They still build a good one? Last setup up was 3/8s rod with 720 open Pressure. they worked great...better then the Crane golds that exploded LOL OldSStroker 12-31-2003, 05:09 PM Originally posted by OneFlyn95z28 I ahve always had good luck with Smith Bro's rods. It has been a while. They still build a good one? Yep. They got out of the cough drop business and stick pretty much to pushrods. arnie 01-01-2004, 09:32 AM Originally posted by OldSStroker Yep. They got out of the cough drop business and stick pretty much to pushrods. :lol: :lol: Experience with a sense of humor. That's cool. OldSStroker 01-01-2004, 10:02 AM Originally posted by arnie :lol: :lol: Experience with a sense of humor. That's cool. Question: How do you tell if an engineer is an extrovert? Answer: He looks at your shoes instead of his own when he talks with you. Not original, but often true. rskrause 01-01-2004, 12:03 PM Originally posted by OldSStroker Question: How do you tell if an engineer is an extrovert? Answer: He looks at your shoes instead of his own when he talks with you. Not original, but often true. :lol: Fits my engineer friends all too well. Rich Krause OneFlyn95z28 01-01-2004, 12:15 PM LOL! Here the the Seattle area we have FAR to many Engineers;) Oldstroker when was the last time one came in and told us just to fix XXX problem because that is what the book said is wrong? Many get WAY to confused when you finaly do agree to there terms(just fix what 'I' tell you so you do not rip me off) and then ask them if they would like find the fault that caused the problem to begin with :D As many here know Experiance can not be learned in any book ;) Those who believe it can will be lost until they discover the truth. One of the best Engineers I ever met never told me he 'was' one ;) OldSStroker 01-01-2004, 12:39 PM Originally posted by OneFlyn95z28 One of the best Engineers I ever met never told me he 'was' one ;) Some of the people I know who have a superior grasp of "how the world works" aren't degreed engineers. Some who haven't a real clue are. Go figure. (subtle engineering joke. :) ) When I was younger...lots younger...I had the good fortune to be exposed to some really fine engineers. I listened a lot and learned a lot. A few were "shoe watchers", but most were real people with some education, a great mind, and lots of experience. The group was the dictionary definition of synergism. I think very successful race teams are much like that. LT1 1980 malibu 01-01-2004, 04:52 PM doesnt the benifit of a loss of rotaing friction loss..Compared to my canted valve small block with jesels my new 406 is way harder to turn over.. Jesel told me that shafts take less toturn over due to the geometry..Is this true? crashbox455 01-01-2004, 07:47 PM Originally posted by LT1 1980 malibu doesnt the benifit of a loss of rotaing friction loss..Compared to my canted valve small block with jesels my new 406 is way harder to turn over.. Jesel told me that shafts take less toturn over due to the geometry..Is this true? a guess, but i don't think the difference is due much at all to the rockers. BUT- i would imagine the difference is much more noticeable at 4000-up than it is at "wrenchspeed". | ||
