joecool72 12-26-2003, 12:13 PM Hi all, before I run out to buy a new Rear Defog switch, I want to make sure this is the issue...
On my '96 Z, when I turn it on, it always shuts off way before the rear window is defogged. Once I try to turn it back on, it doesn't turn on immediately. I normally have to wait a few minutes, then it turns on again, but it always shuts off early again.
I've checked the connections on the glass and I've checked the fuse and everything is good.
Is it the switch or is there something else I'm missing?
Thanks!
Dwaynez28 12-26-2003, 01:06 PM I dont remember all the particulars, But on mine,the power seat and the defogger is on the same circuit, i would adjust my seat, defogger go out--its a relay i think on the driver side fuse box that is bad--"seems" like i read you can replace the relay with a fuse and it will help correct that little problem--just to be safe you might want to do a search on it--Dwayne:)
Mtrhds94Z 12-26-2003, 02:17 PM Yes replace the circuit breaker with a 30 amp fuse...
see this thread from my post down:
http://web.camaross.com/forums/showthread.php?s=&threadid=203276
Red96Lt1 12-26-2003, 02:22 PM I had the same problem and replaced it with a fuse and it stays on for almost 10 min like it's suppoes to.
joecool72 12-26-2003, 07:00 PM Originally posted by Mtrhds94Z
Hey thanks guys, you made my day! :D
Replaced it with an extra fuse I had in my tool box and she works long now!
Any reason why it's just a matter of changing the 30A Circuit Breaker to a 30A Fuse??? Just curious....
Mtrhds94Z 12-26-2003, 07:36 PM Originally posted by joecool72
My theory is that the CB gets 'tired/lazy' as it ages.. and trips at less than 30 amps.. and the fuse carrys the rated 30 amps better....
I had the same problem, fuse works better for me too.
The 30 Amp breaker develops a layer of corrosion/crust on the contacts, which increases its resistance, which makes it overheat at a much lower current draw. You can pop open the breaker's cover and clean the contact with a piece of fine sandpaper. The nice thing about a breaker is it will reset itself, where a fuse needs to be replaced.
BTW, I put a fuse in mine.
Nitelite 09-11-2006, 09:07 AM Oh how I love the search feature. Seems like alot of people have had this problem. Gonna go put a fuse in mine now :D
Thanks a ton guys! This forum rocks.
shoebox 09-11-2006, 09:18 AM The 30 Amp breaker develops a layer of corrosion/crust on the contacts, which increases its resistance, which makes it overheat at a much lower current draw. You can pop open the breaker's cover and clean the contact with a piece of fine sandpaper. The nice thing about a breaker is it will reset itself, where a fuse needs to be replaced.
Long ago, the first thing I tried was a brand new breaker. No joy. I've been using a 30A fuse for 6+ years.
CamaroUK 09-11-2006, 08:02 PM I replaced my circuit breaker with a 30 amp fuse due to the fact it kept switching off too soon.
It was fine until I pulled off the fuse panel and found that the 30A fuse had melted, both the metal and plastic of the fuse. :eek: I had to pull the fuse teeth out with pliers. :confused:
I guess I have a short somewhere or something, you should check you don't have the same problem. I guess my breaker may have been doing its job in the first place.
shoebox 09-11-2006, 08:08 PM I replaced my circuit breaker with a 30 amp fuse due to the fact it kept switching off too soon.
The defogger pulls a lot of juice. The fuse may get deformed, but should blow if too much current is pulled. Keep a spare fuse or two handy and check it every once in a while.
CamaroUK 09-11-2006, 08:14 PM I was suspicious as to why it did'nt just blow. I assumed it may have been a faulty fuse or something that took more current than it should have.
I have not actually tried another 30A fuse since, I just put the old breaker back in. Maybe I should try a new fuse and see if the same happens again. :)
Nitelite 09-12-2006, 09:05 AM I had the same thing happen with the fuse. The plastic just ran right off the metal. I got a bit worried, and saw someone say about taking some sandpaper to the terminals of the breaker. Did that and the thing stays on for the full 10 minutes :D I do still have a few 30 amp fuses in the glove box though, because i'm sure it will come back sooner or later.
